Certbot + post hook + vsftpd
My domain is: ftps.sis.tv
I ran this command:N/A
It produced this output:N/A
My web server is (include version):vsftpd-3.0.3-33
The operating system my web server runs on is (include version):RedHat 8.4
My hosting provider, if applicable, is: Azure
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): ni
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.14.0
I previously reported my issue at: Certbot + post hook + vsftpd
the recommendation was to use a script as post hook.
that still hasn't resolved my issue, the cert renewal fails to call the post hook
extract from log at time of cert renewal:
2022-09-16 10:48:39,062:DEBUG:certbot.display.util:Notifying user: new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/ftps.sis.tv/fullchain.pem
2022-09-16 10:48:39,063:DEBUG:certbot._internal.plugins.selection:Requested authenticator standalone and installer None
I'm not seeing that from the tiny part of the log file you've posted. The words about not reloading is probably related to the nginx and apache plugins when using the certonly subcommand.
Can you post the related renewal configuration file?
Which Challenge Types - Let's Encrypt are you using?
Using https://letsdebug.net/ all 3 Challenge Types either have ERRORS or WARNINGS
  1. HTTPS-01 Let's Debug
  2. DNS-01 Let's Debug
  3. TLS-ALPN-01 Let's Debug
Best Practice - Keep Port 80 Open
Hi Bruce,
I'm using HTTPS-01.
Hi Osiris,
the renewal files are:-
"/etc/systemd/system/certbot-renewal.service"
which currently contains:-
"[Unit]
Description=Certbot Renewal
[Service]
ExecStart=/usr/bin/certbot renew --post-hook "/root/scripts/vsftpd-restart.sh"
and that post-hook script file contains:-
"#!/bin/sh
/usr/bin/systemctl status vsftpd.service
/usr/bin/systemctl restart vsftpd.service
/usr/bin/systemctl status vsftpd.service"
the permissions on the script file are:-
"-r-xr-----. 1 root root 324 Jun 30 11:32 /root/scripts/vsftpd-restart.sh
so it has execute permission, and it runs when called manually from the command line.
You will need Best Practice - Keep Port 80 Open
Hi Bruce,
I don't want to wander up that avenue unnecessarily.
the actual cert is renewing fine, what is not happening is the ftp application is not being bounced as part of post hook, so the old certificate is still being used by the ftp server application, even though a new certificate is obtained by certbot.
Thanks, that is good to know; as often I cannot see the forest through the trees. :crazy_face:
@g-spencer Osiris meant for you to show the renewal file for that cert in /etc/letsencrypt/renewal
Hi MikeMcQ,
as requested:-
cat /etc/letsencrypt/renewal/ftps.sis.tv.conf
version = 1.14.0
archive_dir = /etc/letsencrypt/archive/ftps.sis.tv
cert = /etc/letsencrypt/live/ftps.sis.tv/cert.pem
privkey = /etc/letsencrypt/live/ftps.sis.tv/privkey.pem
chain = /etc/letsencrypt/live/ftps.sis.tv/chain.pem
fullchain = /etc/letsencrypt/live/ftps.sis.tv/fullchain.pem
[renewalparams]
account = 9fdf...ba1f
pref_challs = http-01,
authenticator = standalone
post_hook = systemctl restart postfix
So no vsftpd post/deploy hook is actually configured, only Postfix. No wonder it doesn't work.
Usually, one would not use the post hook command from within a systemd timer, but configure Certbot properly so that the renewal configuration file contains the appropriate command.
OK thanks for highlighting that, I originally set it up to restart postfix as part of the testing.
I'll look at getting the correct configuration, do I just edit the file ?
thanks,
That can't be right.
why'd you say that?
from my understanding, certbot starts an http listener only for the renewal process and then shuts down again
I've updated /etc/letsencrypt/renewal config file.
will monitor and report on future findings,
thanks Osiris / MikeMcQ
actually, I've just dry-runned the renewal and vsftpd service has been restarted:-
certbot renew --dry-run
Because there is no active HTTPS-01 authentication method allowed.
I think you must have meant HTTP-01.
That could be my fault for previously using HTTPS-01 in this Topic when I meant HTTP-01, sorry. :frowning:
I think I have edited them to be HTTPS-01 now.
Could that be "deploy_hook"?
Yes, agreed probably better hook. Just noting it is --deploy-hook in command prompt but translates to renew_hook in renewal conf file.
Hi Bruce5051,
yes, sorry, HTTP-01 for the challenge, not HTTPS-01 (well spotted)
rg305 / MikeMcQ,
as for the conf file, the parameter specified in my conf file is 'post_hook', I don't know if that's 'better practice', but seemed to work for the dummy run.
