Certbot renew hook not working
cirs.forward-scatter.com
certbot --renew (via cron job)
2021-09-20 04:33:12,842:DEBUG:certbot._internal.storage:Writing new private key to /etc/letsencrypt/archive/cirs.forward-scatter.com/privkey6.pem.
2021-09-20 04:33:12,842:DEBUG:certbot._internal.storage:Writing certificate to /etc/letsencrypt/archive/cirs.forward-scatter.com/cert6.pem.
2021-09-20 04:33:12,843:DEBUG:certbot._internal.storage:Writing chain to /etc/letsencrypt/archive/cirs.forward-scatter.com/chain6.pem.
2021-09-20 04:33:12,843:DEBUG:certbot._internal.storage:Writing full chain to /etc/letsencrypt/archive/cirs.forward-scatter.com/fullchain6.pem.
2021-09-20 04:33:12,861:DEBUG:certbot._internal.storage:Writing new config /etc/letsencrypt/renewal/cirs.forward-scatter.com.conf.new.
2021-09-20 04:33:12,866:INFO:certbot.compat.misc:Running deploy-hook command: /etc/letsencrypt/renewal-hooks/deploy/reload_apache.sh
2021-09-20 04:33:12,891:DEBUG:certbot.display.util:Notifying user: new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/cirs.forward-scatter.com/fullchain.pem
2021-09-20 04:33:12,894:DEBUG:certbot._internal.plugins.selection:Requested authenticator webroot and installer None
2021-09-20 04:33:12,894:DEBUG:certbot.display.util:Notifying user:
2021-09-20 04:33:12,894:DEBUG:certbot.display.util:Notifying user: Congratulations, all renewals succeeded:
2021-09-20 04:33:12,894:DEBUG:certbot.display.util:Notifying user: /etc/letsencrypt/live/cirs.forward-scatter.com/fullchain.pem (success)
2021-09-20 04:33:12,894:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2021-09-20 04:33:12,894:DEBUG:certbot._internal.renewal:no renewal failures
Apache/2.4.46
MacOs 11.4
None
no
1.14.0
After creating my certificates just fine, the log above has:
The contents of this file are:
#!/bin/sh
apachectl graceful
So I would think my apache has been gracefully restarted and that newer pages would have the updated credentials. However visiting the web site, I'm still seeing the certificate that is about to expire in three weeks.
If I run the deploy/reload_apache.sh by hand (which I just did), it works fine. If I renew my certificate by using a --force-renewal, it works fine. It only fails when the certificate is renewed as part of a cron job.
Might not do what you would be expecting.
Their documentation shows:
apachectl -k graceful
See: Stopping and Restarting Apache HTTP Server - Apache HTTP Server Version 2.4
Symptoms like this make me immediately suspect $PATH problems.
Process trees which are started by cron (such as cron→certbot→reload_apache.sh) often have a more basic $PATH environment variable than e.g. the $PATH you see in your terminal.
If your shell script calls programs without using their absolute path, there's a chance that they won't run properly when invoked by the cron daemon.
I'm not a macOS user so I don't know what the default $PATH is in its crontab, but a fix you could try is to update your deploy hook to use absolute paths for all the programs it invokes, and additionally check the PATH= line in your crontab.
Excellent idea. Unfortunately I won’t find out if this fixes the problem for another two months.
I also noticed that a different launchctl plist includes the following lines:
	<key>EnvironmentVariables</key>
	<dict>
		<key>PATH</key>
		<string>/usr/local/bin:/usr/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin</string>
	</dict>
This adds to the likelihood that you are right. Programs are run without a proper PATH in their environment unless one is set explicitly.
