Help sudo certbot renew --noninteractive --post-hook "service xxx restart" Fails
My domain is: gdc.com
I ran this command: sudo certbot renew --noninteractive --post-hook "service wftpserver restart"
Processing /etc/letsencrypt/renewal/gdc.com.conf
Failed to renew certificate gdc.com with error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.')
  /etc/letsencrypt/live/gdc.com/fullchain.pem (failure)
My web server is (include version): WingFTP Server 7.2
My hosting provider, if applicable, is: Linux ubftp 5.15.0-69-generic #76-Ubuntu SMP Fri Mar 17 17:19:29 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
Please show file:
Question: doesn't the error message provide enough information to debug your issue further?
As descriptive as that may be...
The Devil's Advocate would argue: But it has always worked before!
So, something isn't going according to plan.
So... what is the plan exactly?
Oh yeah, let's see what's in the renewal.conf file [to better understand how it was able to work last time].
And we should also address:
Why?:
Why not just run "certbot renew" ?
Why add that hook there now?
How was it working before? [deja-vu]
We should look at the renewal.conf file to see why. [deja-vu all over again!]
it states
I do not know what authentication script its referring to
Are you familiar with the "manual" plugin referred in the error message? Did you originally set up Certbot or did perhaps someone else do that?
If you're not familiar with the manual plugin, I'd like to suggest to go read the Certbot documentation about that plugin to familiarise yourself with it. You might even come across something about that authentication script thingy the error message is referring to. Hint: you do.
Why did you just delete the post with the contents of the .conf file? Although the error message is pretty clear, the config file makes it explicit--you'd previously obtained the cert using DNS validation in manual mode, which requires that you manually make changes to your DNS records. In order to automate this (the --noninteractive flag you're using), you need to tell certbot how to make those changes automatically. You do that by using --manual-auth-hook and pointing it to a script that can mmake those updates.
pref_challs = dns-01,
authenticator = manual
You can't "--noninteractive" a "manual" interaction.
I did that by accident I was trying to delete the gibberish I posted but I'm not used to his interface so ...
Did so by accident
I tried that I get the same error
certbot renew
However did you manage to obtain the last cert?
The renewal.conf shows manual interaction.
I need to restart the service that uses the script
This is the first time running via crontab
I followed a how to and I thought I did everything they suggested . When I executed the commands the first time they seemed to produce results similar to the doc I was following so I thought I was OK
I know you say
But I don't know why you say that
DNS authentication requires that a TXT record be added to your global DNS zone.
That appears to have been done manually on your last renewal.
Manual interactions can't be automated.
I see that you are using Network Solutions DNS [or some reseller]:
gdc.com nameserver = ns35.worldnic.com
gdc.com nameserver = ns36.worldnic.com
If you can find an ACME client that supports that DSP, it may be able to automate the TXT record add [and delete].
Wait are you saying that the TXT contents change each time ?
Yes I initially set it up following a how to text
When you know something that is easy and understood by you, you can easily take for granted how it may not be easy for others
Yes, or you would be able to renew that domain indefinitely.
Domain authentication requires a new verification on each issuance/renewal.
I would think I want my domain renewed forever but there's probably something I'm not understanding
Since I had a conf file with an account and a TXT configured in my DNS I thought the txt script was locked in
Anyone know of a script that works with network solutions to do this TXT thing
You might not own that name forever.
You could sell it, or give it away, tomorrow.
Neither of those things are a script.
Try:
acme.sh
OR maybe the latest version of certbot [v2.6.0]
@rg305 Thank very much for taking the time to help me understands kudos to you !
@rg305 if this were a subdomain say s1.gdc.com would I still need to update the contents of the TXT record when renewing
