task.redsserver.com
certbot certonly \
--dns-cloudflare \
--dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini \
-d task.redsserver.com
Nothing
nginx/1.18.0 (Ubuntu)
Digital Ocean
Yes
No
command won't run
So, i realzied that, I just can't run any commands with certbot, at all, I have already tried reinstalling, and, that did not work. Any command I run, just, hangs indefinitely,.However, if I press "CTRL+C" then, it will dump a python traceback, depending on how long I waited, it will be longer.
this is what I got from pressing it about 5 seconds after running the command.
redkitters@redsserver:~$ certbot
^CTraceback (most recent call last):
File "/snap/certbot/1788/bin/certbot", line 5, in <module>
from certbot.main import main
File "/snap/certbot/1788/lib/python3.8/site-packages/certbot/main.py", line 6, in <module>
from certbot._internal import main as internal_main
File "/snap/certbot/1788/lib/python3.8/site-packages/certbot/_internal/main.py", line 18, in <module>
import josepy as jose
File "/snap/certbot/1788/lib/python3.8/site-packages/josepy/__init__.py", line 43, in <module>
from josepy.json_util import (
File "/snap/certbot/1788/lib/python3.8/site-packages/josepy/json_util.py", line 14, in <module>
from OpenSSL import crypto
File "/snap/certbot/1788/lib/python3.8/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/snap/certbot/1788/lib/python3.8/site-packages/OpenSSL/crypto.py", line 17, in <module>
from OpenSSL._util import (
File "/snap/certbot/1788/lib/python3.8/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/snap/certbot/1788/lib/python3.8/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module>
from cryptography.hazmat.bindings._openssl import ffi, lib
File "<frozen importlib._bootstrap>", line 986, in _find_and_load
KeyboardInterrupt
Thank You for your time.
