Certbot NGINX Cloudflare Issue
music.jordanpicton.xyz
sudo certbot -v --nginx -d jordanpicton.xyz
Requesting a certificate for jordanpicton.xyz
http-01 challenge for jordanpicton.xyz
Challenge failed for domain jordanpicton.xyz
  Domain: jordanpicton.xyz
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "C0eBdELqUFvSskRWK9LN9uU5uL1UW05iXnocGjYHWxI.1p5yWDAxv8N_XD8Ic93lZEnYnYbWFwVdeJ5aZh5T9uI" (got "X-Frame-Options: SAMEORIGIN\r\nX-Content-Type-Options: nosniff\r\nX-XSS-Protection: 1; mode")
Distributor ID: Ubuntu
Description:    Ubuntu 24.04.4 LTS
Release:        24.04
Codename:       noble
nginx version:  nginx/1.28.2
certbot:        2.9.0
Ubuntu
Myself.
Yes.
No.
certbot 2.9.0
There appears to be something sending
X-XSS-Protection: 1; mode=block
Content-Security-Policy: default-src 'self'; scrip
as the page body when you request http://jordanpicton.xyz/.well-known/acme-challenge/C0eBdELqUFvSskRWK9LN9uU5uL1UW05iXnocGjYHWxI.1p5yWDAxv8N_XD8Ic93lZEnYnYbWFwVdeJ5aZh5T9uI, try searching your configuration for this as these fields should not be in the body of a 302 response (or any response).
Yeah sorry I meant the music.jordanpicton.xyz.
This was all working before I updated and now I've got multiple issues across a bunch of domains.
But fun to see that I've caused another issue haha.
I'm not fully sure what you're asking me to do here in all honestly.
The only domain I got certbot to work with would have been my forums one when I setup Discourse, which is currently broken as well because of my updates.
Though I most likely have broken the NGINX side of things more than anything really. As some work and then others don't, I was honestly just trying to secure things up a little more but don't know much about this stuff so I've messed up haha.
Isn't that Cloudflares doing instead of nginx?
With Cloudflare I have full-strict on along with an edge certificate, automatic https rewrites enabled, and universal ssl.
Your Content Security Policy header shouldn't contain any newlines (RFC 9110: HTTP Semantics) and have you tried running certbot with the correct subdomain?
Yeah I tried the music subdomain with a similar response.
From what I can see there doesn't seem to be new lines within my CSP either.
I tried to fetch the challenge over HTTP using nc and here's what I got
GET /.well-known/acme-challenge/C0eBdELqUFvSskRWK9LN9uU5uL1UW05iXnocGjYHWxI.1p5yWDAxv8N_XD8Ic93lZEnYnYbWFwVdeJ5aZh5T9uI HTTP/1.0
Host: music.jordanpicton.xyz
HTTP/1.1 404 Not Found
Server: nginx/1.28.2
Date: Sat, 14 Feb 2026 11:39:21 GMT
Content-Type: text/html
Content-Length: 153
Connection: close
    default-src 'self';
    script-src 'self' 'unsafe-inline';
    style-src 'self' 'unsafe-inline' blob:;
    img-src 'self' data: blob:
        https://www.teamspeak.com
        https://res.cloudinary.com;
    font-src 'self' data:;
    connect-src 'self' wss:;
    manifest-src 'self' data:;
    object-src 'none';
    base-uri 'self';
    frame-ancestors 'none';
<html>
<head><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>nginx/1.28.2</center>
</body>
</html>
Yeah I'm kind of rethinking everything at the moment since I've got certbot applying a certificate for my forums which did work until the updates. But the rest of my domains where going through cloudflare and manually assigning the certs.
So I'm going to sit back view my options and setup something better hopefully. I'd like to use certbot I think because of Discourse using it but if I could I'd probably use cloudflare for it but I've just got to see what I can do really.
Have you considered using a Cloudflare Origin CA certificate for your server? Those are very easy to setup. And, do not require using Certbot (or any other standalone ACME Client) to get or renew a cert.
You get this cert from Cloudflare and can set its expiration far in the future. This Origin CA cert is only good for domains proxied at Cloudflare.
I was using these originally for my websites though the forums certbot one was broken mostly. Plus I wouldn't say my network is the best when it comes to security so I removed it all and started to redo most of it a few hours ago.
Though I'd be looking for sysadmin help honestly as I'd want to make sure I'm doing what I can though I'm not sure where I'd start or where to find the help. But safe to say I'm not using certbot anymore currently.
Thanks for the help everyone. :slight_smile:
