Need help with certbot
rena@renaserver:~$ sudo certbot --nginx
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): zypher.site
Requesting a certificate for zypher.site
Domain: zypher.site
Detail: 2606:4700:3035::6815:1a27: Invalid response from http://zypher.site/.well-known/acme-challenge/VqoiOkkiMYLFlHL_AmuGpcNZg74JISdwApdH2PEboDA: 523
this is the error im getting, i have read some of the posts that people posted here but some of the problems are they are using aaaa instead of a but im using a
if someone could help thank you
Your site is completely down, see https://zypher.site/:
Origin is unreachable
You're using Cloudflare CDN. Please make sure you have a working website first.
If you're using Cloudflare, you might want to look into Cloudflares Origin CA certificates instead of using Let's Encrypt certificates on your origin server.
I thought it was supposed to be down? Someone told me to delete all my records and make a new one for a
Supposed to be down for what exactly?
What records? DNS? Please elaborate and/or be more clear/add more details.
yes i mean dns sorry, i had a cname before and that was pointing to another website
a cloudflare pages website
Well, currently there is neither A nor AAAA record in the DNS zone present.
the website is online but its still giving me the same error
Please show the Certbot output of the current issue.
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: zypher.site
blank to select all options shown (Enter 'c' to cancel): zypher.site
** Error - Invalid selection **
1: zypher.site
blank to select all options shown (Enter 'c' to cancel): ^[
1: zypher.site
Domain: zypher.site
Detail: 2606:4700:3036::ac43:875b: Invalid response from http://zypher.site/.well-known/acme-challenge/ld8lCLiXrclGz3EOd_wWfGm4Dt-YA1PJNyKsPGlT9-Q: 404
rena@renaserver:/var/www/tutorial$
Cloudflare can sometimes interfer with the challenge for some reason. I'm not really familiar with Cloudflare and the many options one can enable at Cloudflare, so maybe another volunteer can help you with that.
Alternatively you could still look into the origin certificates from Cloudflare, see the link I posted earlier.
i got everything working i dont get the error anymore but i get a new one i dont have aaaa dns setup but how do i get my ipv6?
You do have AAAA records. They are part of the Cloudflare "proxy" setup you did. These are their current values:
zypher.site.	0	IN	AAAA	2606:4700:3036::ac43:875b
zypher.site.	0	IN	AAAA	2606:4700:3035::6815:1a27
I believe Cloudflare CDN uses IPv4 to your Origin Server unless it is IPv6 only. That is something to discuss on the Cloudflare community or from its docs.
zypher.site
sudo service nginx start
rena@renaserver:/etc/nginx/sites-available$ sudo service nginx start
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xeu nginx.service" for details.
nginx
ubuntu 24.04 lts
nginx? cloudflare?
i dont know
no
certbot 2.11.0
The problem im having is that before i had installed the certbot everything was working fine i could access the website outside of my home wifi but when i installed certbot nginx wont turn on
I moved your new post/thread onto this one. This is a continuing problem and it is helpful for us to see the history in one place.
What do these commands show?
As an alternative to Certbot on your Origin server, have you looked at the link Osiris provided about using a Cloudflare Origin CA cert? That may be far easier for you than the path you are on.
Even that requires a working nginx server though. You need to show the error messages from the above for us to help though.
Hi @renagamer101, and welcome to the LE community forum :slight_smile:
You are using Cloudflare.
And they are using both AAAA and A:
Addresses: 2606:4700:3036::ac43:875b
           172.67.135.91
           104.21.26.39
LE prefers to use the AAAA record when available - as shown in the error message:
Also shown is the "523" message from Cloudflare - which I think means that they can't connect to your site.
You need a working website in order to get an LE cert via HTTP(S).
That said, you may not even need an LE cert - Since you can get a cert directly from Cloudflare.
But do you know why after installing certbot Nginx won’t start? I did the let’s debug thing and it kept saying found a loop or somthing
Now without more info from you. Such as this
Well this is the issue I am having what info do you need more? I can try to provide it
The output of this command
and this command
Right after your start for nginx fails.
