Certbot - Failed authorization procedure - Timeout after connect
My domain is: jenkins.shawmer.com
I ran this command: certbot --staging --nginx -d jenkins.shawmer.com --agree-tos --non-interactive
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for jenkins.shawmer.com
Waiting for verification…
Failed authorization procedure. jenkins.shawmer.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://jenkins.shawmer.com/.well-known/acme-challenge/YnSv9eh2XRxsmcMMtNF_2r3g_AP03mpXh2dnw-yLzF8: Timeout after connect (your server may be slow or overloaded)
    Domain: jenkins.shawmer.com
    Type: connection
    Detail: Fetching
My web server is (include version): nginx/1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04.4 LTS
My hosting provider, if applicable, is: NA
FYI …
Both of the following works …
curl http://jenkins.shawmer.com/.well-known/acme-challenge/test.txt
curl -v -6 http://jenkins.shawmer.com/.well-known/acme-challenge/test.txt
The server allows traffic on port 443
Thanks!
From where did you test that? I cannot connect to your server (port 80).
Alrighty then. That’s all I needed to hear! Resolved :slight_smile:
It’s always the most obvious, simple thing.
Thanks!
