Certbot Docker not saving certificate to volume
My domain is: lucks.hivetown.pt,www.lucks.hivetown.pt
docker run --rm -it \
    --name certbot \
    -p 8888:80 \
    --volume ./data/certbot-etc:/etc/letsencrypt \
    certbot/certbot \
        certonly \
            --force-renew \
            --test-cert --non-interactive --standalone \
            --agree-tos --no-eff-email \
            -d $CERTBOT_DOMAINS --email $CERTBOT_EMAIL
Renewing an existing certificate for lucks.hivetown.pt and www.lucks.hivetown.pt
Certificate is saved at: /etc/letsencrypt/live/lucks.hivetown.pt/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/lucks.hivetown.pt/privkey.pem
This certificate expires on 2023-08-16.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See https://certbot.org/renewal-setup for instructions.
haproxy-alpine:2.6.10, but my issue happens before that
Docker 23.0.4 on Manjaro Linux 6.1.26-1-MANJARO
I can login to a root shell on my machine (yes or no, or I don't know): yes, i am working locally
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0 from dockerhub certbot/cerbot
Further description:
Certbot is saving renewal/lucks.hivetown.pt.conf, but it says it's saving the certificates but they do not appear on my host machine under live directory
Where exactly are you looking for the certificates on your host machine?
On data/certbot-etc/live of the current directory I am at. In data/certbot-etc/renewal I am able to view the lucks.hivetown.pt.conf file with data inside it
Also, I have tried removing --test-cert but with not success.
Please keep using --test-cert (or --staging) for testing purposes, as using the production environment for testing will lead you to running into rate limits.
That's weird. Could you perhaps do a tree ./data/certbot-etc/?
I have found my mistake... I was checking the dir through VSCode which did not have permissions, so it did not list anything.
Sorry :sweat: but thank you!!
Glad you found the issue :slight_smile:
Please also note that you should only use --force-renewal on the staging environment (with --test-cert or --staging) and NOT on the production environment, unless you absolutely know for what purpose you're actually using it. Hint: most users don't know the meaning of the option and use it incorrectly.
