my letsencrypt cert on https://dmfigol.me is expiring very soon and I have a problem with renewing the certificate manually.
To generate certificate I used this guide https://miki725.github.io/docker/crypto/2017/01/29/docker+nginx+letsencrypt.html and it went without any problem.
When I try renewing the certificate, I do not see any attempt to renew:
sudo docker run -it \
> -v certs:/etc/letsencrypt \
> -v certs-data:/data/letsencrypt \
> -v letsencrypt-logs:/var/log/letsencrypt \
> deliverous/certbot:latest \
> renew -v --debug \
> --webroot --webroot-path=/data/letsencrypt
Root logging level set at 10
No renewals were attempted.
no renewal failures
the log file is also empty:
cat letsencrypt.log
2017-09-16 10:28:09,988:DEBUG:certbot.main:certbot version: 0.19.0.dev0
2017-09-16 10:28:09,988:DEBUG:certbot.main:Arguments: ['-v', '--debug', '--webroot', '--webroot-path=/data/letsencrypt']
2017-09-16 10:28:09,988:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2017-09-16 10:28:10,015:DEBUG:certbot.log:Root logging level set at 10
2017-09-16 10:28:10,017:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2017-09-16 10:28:10,018:DEBUG:certbot.renewal:no renewal failures
My certificate is in certs/live/dmfigol.me/
However, certs-data/ is empty. Not sure if it is supposed to be this way.
I would greatly appreciate any help on this. I’ve already spent the whole morning researching without any progress.
Thanks in advance!
UPD: resolved, docker needs full path for attaching volumes.
