Backing up and restoring certs cause certbot to repeatedly renew certs
My domain is: mozib.io
I ran this command: certonly --webroot --noninteractive --email admin@mozib.io --agree-tos --no-eff-email --cert-name certs -w /var/www/html/mozib.io/public_html -d mozib.io -d www.mozib.io
It produced this output: Renewing certificates for mozib.io
My web server is (include version): Apache 2.4.62
The operating system my web server runs on is (include version): Docker on Ubuntu 20.04 using httpd:2.4 container
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 3.0.0
I am running Certbot and Apache on separate Docker containers and link them via a folder in the host, e.g.
services:
    webserver:
        volumes:
            ./certs:/usr/local/apache2/ssl/letsencrypt
    certbot:
        volumes:
            ./certs:/etc/letsencrypt
Everything works fine as long as I don't touch the certs folder on the Docker host. Running the certbot command above reports certificates are not up for renewal, which is correct. However, when I backup the folder, delete its contents and then restore it from the backup, running the certbot command causes certbot to always seek new certificates and ignore the existing ones. New certificates are placed in folders called certs-0001, certs-0002 etc. I ensure all permissions and timestamps are preserved when backing up the certs folder by issuing the command cp -a when copying.
I am just wondering why this is the case.
Thank you.
Do you retain the symlinks when backing up and restore these symlinks?
Because the ../live/... folder are symlinks to the most recent cert in ../archive/..
A few of the most recent are retained in ../archive/.. for various purposes
After deleting and restoring what does this show
sudo -lR ./certs
Oh no I didn't check the symlinks and you're right, the symlinks are missing when I restore the backups.
Before backing up:
lrwxrwxrwx 1 root root  29 Oct 31 18:08 cert.pem -> ../../archive/certs/cert7.pem
lrwxrwxrwx 1 root root  30 Oct 31 18:08 chain.pem -> ../../archive/certs/chain7.pem
lrwxrwxrwx 1 root root  34 Oct 31 18:08 fullchain.pem -> ../../archive/certs/fullchain7.pem
lrwxrwxrwx 1 root root  32 Oct 31 18:08 privkey.pem -> ../../archive/certs/privkey7.pem
-rw-r--r-- 1 root root 692 Dec 31  2023 README
After restoring:
-rw-r--r-- 1 root root 1363 Oct 31 18:08 cert.pem
-rw-r--r-- 1 root root 1566 Oct 31 18:08 chain.pem
-rw-r--r-- 1 root root 2929 Oct 31 18:08 fullchain.pem
-rw------- 1 root root  241 Oct 31 18:08 privkey.pem
Once I restore with symlinks everything works properly!
Many thanks for your help!
