Certbot : Depends: python-certbot (= 0.10.2-1~bpo8+1) but it is not going to be installed
Hello
I run
sudo apt-get install certbot -t jessie-backports
And Get
The following packages have unmet dependencies:
 certbot : Depends: python-certbot (= 0.10.2-1~bpo8+1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 8.2 (jessie)
Release:	8.2
Codename:	jessie
I don’t know how to solve the problem with the package conflict, but there have been issues with the Debian repos. previously.
You may have better luck using the platform-independent certbot-auto installer instead.
