Have tried to obtain a certificate for a domain hybridized.club, but certbot container ends up with Exited (1) error.
docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
5829d999bdf2 certbot/certbot "certbot certonly --…" 26 minutes ago Exited (1) 26 minutes ago certbot
3bd18e5813cf nginx:1.15.12-alpine "nginx -g 'daemon of…" 26 minutes ago Up 26 minutes 0.0.0.0:80->80/tcp webserver
eb24d72a9501 wordpress:5.1.1-fpm-alpine "docker-entrypoint.s…" 26 minutes ago Up 26 minutes 9000/tcp wordpress
565b074d79c1 mysql:8.0 "docker-entrypoint.s…" 26 minutes ago Up 26 minutes 3306/tcp, 33060/tcp db
organic@desktop:~/dev/docker/wordpress$ docker logs certbot
Account registered.
Requesting a certificate for hybridized.club and www.hybridized.club
http-01 challenge for hybridized.club
http-01 challenge for www.hybridized.club
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain www.hybridized.club
Challenge failed for domain hybridized.club
Domain: www.hybridized.club
Detail: Invalid response from
http://www.hybridized.club/.well-known/acme-challenge/YXUulLj8CZfA8u3Di5d_9xsbYRaqsysdo72w2gHrFZg
[217.15.151.47]: 404
Domain: hybridized.club
http://hybridized.club/.well-known/acme-challenge/rYleaMwCt7nLl2URBXLTTyuaw2YwJkyGZYDEDHjEclE
217.15.151.47
Ubuntu 20.04
self-hosted
Docker compose file:
version: '3'
services:
db:
image: mysql:8.0
container_name: db
restart: unless-stopped
env_file: .env
environment:
- MYSQL_DATABASE=wordpress
volumes:
- dbdata:/var/lib/mysql
command: '--default-authentication-plugin=mysql_native_password'
networks:
- app-network
wordpress:
depends_on:
- db
image: wordpress:5.1.1-fpm-alpine
container_name: wordpress
env_file: .env
environment:
- WORDPRESS_DB_HOST=db:3306
- WORDPRESS_DB_USER=$MYSQL_USER
- WORDPRESS_DB_PASSWORD=$MYSQL_PASSWORD
- WORDPRESS_DB_NAME=wordpress
volumes:
- wordpress:/var/www/html
networks:
- app-network
webserver:
depends_on:
- wordpress
image: nginx:1.15.12-alpine
container_name: webserver
ports:
- "80:80"
volumes:
- ./nginx-conf:/etc/nginx/conf.d
- certbot-etc:/etc/letsencrypt
networks:
- app-network
certbot:
depends_on:
- webserver
image: certbot/certbot
container_name: certbot
volumes:
command: certonly --webroot --webroot-path=/var/www/html --email tamerlanium@gmail.com --agree-tos --no-eff-email --staging -d hybridized.club -d www.hybridized.club
volumes:
certbot-etc:
wordpress:
dbdata:
networks:
app-network:
driver: bridge
Nginx file:
listen 80;
listen [::]:80;
server_name hybridized.club www.hybridized.club;
index index.php index.html index.htm;
root /var/www/html;
location ~ /.well-known/acme-challenge {
allow all;
root /var/www/html;
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass wordpress:9000;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
location ~ /\.ht {
deny all;
location = /favicon.ico {
log_not_found off; access_log off;
location = /robots.txt {
log_not_found off; access_log off; allow all;
location ~* \.(css|gif|ico|jpeg|jpg|js|png)$ {
expires max;
log_not_found off;
Godaddy domain settings:
