My domain is: staging.ishankhare.com
I ran this command: certbot certonly --noninteractive --agree-tos --staging --standalone -d staging.ishankhare.com -m me@ishankhare.com
http-01 challenge for staging.ishankhare.com
Waiting for verification…
Failed authorization procedure. staging.ishankhare.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://staging.ishankhare.com/.well-known/acme-challenge/tpumqbcDWudT7EBsgC7IvtSzZvMAuooQ3PmSPh9yng8: Timeout during connect (likely firewall problem)
Domain: staging.ishankhare.com
Type: connection
Detail: Fetching
My web server is (include version): standalone
The operating system my web server runs on is (include version): certbot/certbot docker container
My hosting provider, if applicable, is: gcloud
What is weird is when i use the same container on a compute instance instead of kubernetes, it works perfectly and is able to verify my domain.
