My domain is: youthministry.rccghopmn.org
I ran this command: sudo certbot --nginx
ubuntu@ip-172-31-85-195:~$ sudo certbot --nginx
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: youthministry.rccghopmn.org
2: www.youthministry.rccghopmn.org
Requesting a certificate for youthministry.rccghopmn.org and www.youthministry.rccghopmn.org
Domain: www.youthministry.rccghopmn.org
Detail: 192.185.21.16: Invalid response from http://www.youthministry.rccghopmn.org/.well-known/acme-challenge/urqTQaLs4JZeZLQNyCJfUIC2Du6hteQ4ULVEbjt_DX0: 404
Domain: youthministry.rccghopmn.org
Detail: 192.185.21.16: Invalid response from http://youthministry.rccghopmn.org/.well-known/acme-challenge/q3YBhpVs3DJxfex0kDLhS7lTNQOyS5OukglHvBGICAo: 404
My web server is (include version): nginix
The operating system my web server runs on is (include version): Ubuntu 24.04.2 LTS
My hosting provider, if applicable, is: HostGator/AWS
or certbot-auto --version
if you're using Certbot): certbot --version
Description of issue:
I am trying to configure SSL/TSL for a subdomain. The subdomain runs on an AWS EC2 instance while the main domain runs on web hosting with Hostgator. I changed the A record of the main domain with the domain registrar, Hostgator.com to point to the public ip address of the AWS server (EC2 instance) which runs the web app served at the subdomain.
The IP address in the error message seems to resolve to Hostgator.
I will appreciate any help/useful suggestions.
Thanks.
