Help with ssl certificate in AWS EC2 instance
Hello,
My domain is: pritamdey.in
I ran this command: sudo certbot --nginx
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: ec2-54-91-247-129.compute-1.amazonaws.com
Requesting a certificate for ec2-54-91-247-129.compute-1.amazonaws.com
An unexpected error occurred:
Error creating new order :: Cannot issue for "ec2-54-91-247-129.compute-1.amazonaws.com": The ACME server refuses to issue a certificate for this domain name, because it is forbidden by policy
My web server is (include version): AWS EC2
The operating system my web server runs on is (include version): Ubuntu 20
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
Any help is appreciated.
Thanks,
Pritam
Hi @pritam-dey3, and welcome to the LE community forum :slight_smile:
You should first create a vhost for your domain.
Create a website that responds to: http://pritamdey.in/
You may need to update the DNS also:
Address: 185.199.108.153
Note: The www seems to already be in use at github:
Addresses: 2606:50c0:8000::153
           2606:50c0:8001::153
           2606:50c0:8002::153
           2606:50c0:8003::153
           185.199.108.153
           185.199.109.153
           185.199.110.153
           185.199.111.153
Aliases:   www.pritamdey.in
Thanks a lot. It worked.
