Certbot certonly webroot validation fail
Domain: mail.accinside.co.kr
My web server(include version): Linux centos7.3 64bit
certbot certonly --webroot
This command creates a temporary file under ‘/var/www/html/.well-known/acme-challenge/’ directory, but
the http request from letsencrypt fails to validate the file.
My Website listens on both http and https ports
Please help me out
    Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'to cancel):
    http-01 challenge for mail.accinside.co.kr
    Select the webroot for mail.accinside.co.kr:
    1: Enter a new webroot
    Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
    Input the webroot for mail.accinside.co.kr: (Enter 'c' to cancel):/var/www/html
    Failed authorization procedure. mail.accinside.co.kr (http-01): urn:acme:error:connection ::
    The server could not connect to the client to verify the domain ::
    Fetching http://mail.accinside.co.kr/.well-known/acme-challenge/xxxxxxxxxx: Timeout
       Type:   connection
       Detail: Fetching
       http://mail.accinside.co.kr/.well-known/acme-challenge/xxxxxxxxxxxxxx:
       Timeout
Hi @warren,
I’m not able to access http://mail.accinside.co.kr/ with a browser at all (it also times out for me), from different vantage points in the U.S. Can you access it in a browser from a network other than the one that it’s hosted on? Do you have recent evidence that someone else has accessed it from outside of Korea?
Thank you for the reply @schoen
I don’t have the evidence, but this link might work for proving the aceess outside of Korea
http://mail.accinside.co.kr/ is set to redirect to https port.
Because the website doesn’t contain ssl certificate yet, the browser won’t show the page.
That domain is resolving to 116.122.36.38 for me, which is not responding on either port 80 or port 443. It seems you need to fix some connectivity issues with your server.
Nope, I'm not getting a certificate error. The TCP connection never completes at all. It won't work with curl or telnet either.
You were right! Thank you
