My domain is: worldoilcorps.com
I ran this command: sudo certbot certonly -d worldoilcorps.com
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Requesting a certificate for worldoilcorps.com
Domain: worldoilcorps.com
Detail: Invalid response from http://worldoilcorps.com/.well-known/acme-challenge/CVvBOetNSAaa-scQ2_SjnyqhxYa_aCdIVCxSsQ83Kgo [34.102.136.180]: "<!doctype html><html lang="en"><meta http-equiv="content-type" content="text/html;charset=utf-8"><meta name="viewport" con"
The operating system my web server runs on is (include version): Linux kali 5.10.0-kali9-cloud-amd64 #1 SMP Debian 5.10.46-4kali1 (2021-08-09) x86_64 GNU/Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.18.0
