Certbot certification issue
My domain is: webwork1.cc.uregina.ca
1: webwork1.cc.uregina.ca
Requesting a certificate for webwork1.cc.uregina.ca
Domain: webwork1.cc.uregina.ca
Type: connection
Detail: XXX.X.XXX.XX: Fetching http://webwork1.cc.uregina.ca/.well-known/acme-challenge/iKiXdld9KFr1iaYvPZJjhxreeIKwYYzvnst31oMUM74: Timeout during connect (likely firewall problem)
Version:  Linux version 5.4.0-120-generic (buildd@lcy02-amd64-006) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #136-Ubuntu SMP Fri Jun 10 13:40:48 UTC 2022
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.29.0
Welcome to the community @caron24k !
In order to obtain certificates from Let's Encrypt, your site must be availble on the internet. Something is getting in the way of public access.
PORT    STATE    SERVICE
22/tcp  filtered ssh
80/tcp  filtered http
443/tcp filtered https
You might check either your firewall or contact your ISP to verify if they are blocking your ports or not.
Hello,
I am currently using firewalld and have these specific settings:
wwadmin@webwork1:~$ sudo firewall-cmd --list-all
[sudo] password for wwadmin:
public
target: default
icmp-block-inversion: no
interfaces:
sources:
services: dhcpv6-client http https ssh
ports:
protocols:
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules:
http https and ssh are all allowed.
I can also reach my server through the browser by going to http://webwork1.cc.uregina.ca:80
Are you accessing the site from within your own network? If so, use a phone or pad or something and turn your wifi off and try accessing from that device. (all I am getting are timeouts, unfortunately.)
I can concur: your host at webwork1.cc.uregina.ca is completely down from the perspective of the public internet.
Please also check NAT portmaps if applicable.
0 for 3, I too have a problem reaching that site:
curl -Ii http://webwork1.cc.uregina.ca/
I got this
$ curl -Ii http://webwork1.cc.uregina.ca/
HTTP/1.1 200 OK
Date: Mon, 25 Jul 2022 19:09:02 GMT
Server: Apache/2.4.41 (Ubuntu)
Last-Modified: Mon, 09 Aug 2021 23:38:13 GMT
ETag: "2aa6-5c928e0f1d0db"
Accept-Ranges: bytes
Content-Length: 10918
Vary: Accept-Encoding
Content-Type: text/html
@Bruce5051
I get that too now.
[making progess!]
Nice @rg305 :slightly_smiling_face:
Hello,
The original hypothesis was correct. Out network team told me they opened it up but really they didn't. So I had local access from the inner network but not outside the companies network. Networking opened up the http channel and I was able to get the certificate and everything works. Appreciate all the help and support from the community members here.
Still down for me tho :frowning_face:
Sill up for me; maybe @caron24k's firewall team doesn't have the problem full resolved for all of the internet yet. IPv4 vs IPv6?
I'm using IPv4 myself.
I see only one IP:
Address: 142.3.152.39
So, it's probably something more like GEO-blocking.
Works for me!
Totally agree. Site24x7 test says only North America sites can connect.
EDIT: Let's Encrypt will need http connectivity from North America and Europe, at minimum, to satisfy http challenge. Other regions may be needed in future. Let's Encrypt recommends port 80 be open for all visitors.
And it seems not all of the USA can even reach the site Check website performance and response: Check host - online website monitoring
Hmm. I don't know how reliable that site is. I just tried it and none of their locations found the site. That test site also did not find letsencrypt.org or this forum from any of their locations either so that's not a good sign. I tried http and ping and nothing. Maybe they are just having a bad day :slight_smile:
It is usual reliable, I guess they could be having an off day.
I can still reach it though.
