Certbot certificate issue
My domain is:portalrpa.inforvio.in
I ran this command:"#!/bin/bash
if ! [ -x "$(command -v docker-compose)" ]; then
echo 'Error: docker-compose is not installed.' >&2
exit 1
fi
domains=(portalrpa.inforvio.in)
rsa_key_size=4096
data_path="./data/certbot"
email="ajith@loanwiser.in" # Adding a valid address is strongly recommended
staging=0 # Set to 1 if you're testing your setup to avoid hitting request limits
if [ -d "$data_path" ]; then
read -p "Existing data found for $domains. Continue and replace existing certificate? (y/N) " decision
if [ "$decision" != "Y" ] && [ "$decision" != "y" ]; then
exit
fi
fi
if [ ! -e "$data_path/conf/options-ssl-nginx.conf" ] || [ ! -e "$data_path/conf/ssl-dhparams.pem" ]; then
echo "### Downloading recommended TLS parameters ..."
mkdir -p "$data_path/conf"
curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot-nginx/certbot_nginx/_internal/tls_configs/options-ssl-nginx.conf > "$data_path/conf/options-ssl-nginx.conf"
curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot/certbot/ssl-dhparams.pem > "$data_path/conf/ssl-dhparams.pem"
echo
fi
echo "### Creating dummy certificate for $domains ..."
path="/etc/letsencrypt/live/$domains"
sudo mkdir -p "$data_path/conf/live/$domains"
docker-compose run --rm --entrypoint "
openssl req -x509 -nodes -newkey rsa:$rsa_key_size -days 1
-keyout '$path/privkey.pem'
-out '$path/fullchain.pem'
-subj '/CN=localhost'" certbot
echo
echo "### Starting nginx ..."
docker-compose up --force-recreate -d nginx
echo
echo "### Deleting dummy certificate for $domains ..."
rm -Rf /etc/letsencrypt/live/$domains &&
rm -Rf /etc/letsencrypt/archive/$domains &&
rm -Rf /etc/letsencrypt/renewal/$domains.conf" certbot
echo
echo "### Requesting Let's Encrypt certificate for $domains ..."
#Join $domains to -d args
domain_args=""
for domain in "${domains[@]}"; do
domain_args="$domain_args -d $domain"
done
Select appropriate email arg
case "$email" in
"") email_arg="--register-unsafely-without-email" ;;
*) email_arg="--email $email" ;;
esac
Enable staging mode if needed
if [ $staging != "0" ]; then staging_arg="--staging"; fi
certbot certonly --webroot -w /var/www/certbot
$staging_arg
$email_arg
$domain_args
--rsa-key-size $rsa_key_size
--agree-tos
--force-renewal" certbot
echo
echo "### Reloading nginx ..."
docker-compose exec nginx nginx -s reload"
It produced this output: "Existing data found for portalrpa.inforvio.in. Continue and replace existing certificate? (y/N) y
./init-letsencrypt.sh: line 25: ./data/certbot/conf/options-ssl-nginx.conf: Permission denied
./init-letsencrypt.sh: line 26: ./data/certbot/conf/ssl-dhparams.pem: Permission denied
Creating dummy certificate for portalrpa.inforvio.in ...
[+] Building 0.0s (0/0)
Generating a RSA private key
writing new private key to '/etc/letsencrypt/live/portalrpa.inforvio.in/privkey.pem'
Starting nginx ...
[+] Running 1/1
:check_mark: Container ubuntu-nginx-1 Started 0.4s
Deleting dummy certificate for portalrpa.inforvio.in ...
Requesting Let's Encrypt certificate for portalrpa.inforvio.in ...
Requesting a certificate for portalrpa.inforvio.in
Domain: portalrpa.inforvio.in
Type: connection
Detail: 35.154.100.196: Fetching http://portalrpa.inforvio.in/.well-known/acme-challenge/f5xs3dgBu1YBdoUqLCi0HS83gGT1OBn05k0e8E8iLpc: Connection refused
Reloading nginx ...
service "nginx" is not running container #1"
My web server is (include version):latest
ubuntu
My hosting provider, if applicable, is:aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):latest
I don't follow your script but at this step it means the Let's Encrypt server was not able to reach your domain using that URL. You likely have a firewall blocking access. Or, your Docker containers are not setup properly to receive this request.
Existing data found for loanportal.inforvio.in. Continue and replace existing certificate? (y/N) y
Creating dummy certificate for loanportal.inforvio.in ...
mkdir: cannot create directory ‘./data/certbot/conf/live’: Permission denied
[+] Running 13/13
:check_mark: certbot 12 layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 7.1s
:check_mark: 91d30c5bc195 Pull complete 0.9s
:check_mark: 5d0bb5b9b8b7 Pull complete 1.2s
:check_mark: 9369f9a4ffc3 Pull complete 2.0s
:check_mark: d7106b6bd561 Pull complete 2.0s
:check_mark: 8c76a60d2b3a Pull complete 2.4s
:check_mark: e08bf95bbd48 Pull complete 2.4s
:check_mark: 26174528a65c Pull complete 2.4s
:check_mark: 41fea484b2e1 Pull complete 2.4s
:check_mark: 5dd9ac53b45b Pull complete 2.5s
:check_mark: 899e8acb0a4c Pull complete 2.7s
:check_mark: dad4a746029b Pull complete 3.0s
:check_mark: b524cdf16a36 Pull complete 4.0s
writing new private key to '/etc/letsencrypt/live/loanportal.inforvio.in/privkey.pem'
req: Can't open "/etc/letsencrypt/live/loanportal.inforvio.in/privkey.pem" for writing, No such file or directory
Starting nginx ...
[+] Running 1/1
:check_mark: Container ubuntu-nginx-1 Started 0.6s
Deleting dummy certificate for loanportal.inforvio.in ...
Requesting Let's Encrypt certificate for loanportal.inforvio.in ...
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: y
Account registered.
Requesting a certificate for loanportal.inforvio.in
Domain: loanportal.inforvio.in
Type: connection
Detail: 35.154.100.196: Fetching http://loanportal.inforvio.in/.well-known/acme-challenge/XSYb2fqsEgXTu2_Rj2jttR2Kp9qtXlh4Y48w-b23YjE: Connection refused
Reloading nginx ...
this is my docker-compose file
version: '3'
services:
nginx:
image: nginx:1.15-alpine
ports:
- "80:80"
- "443:443"
volumes:
- ./data/nginx:/etc/nginx/conf.d
- ./data/certbot/conf:/etc/letsencrypt
- ./data/certbot/www:/var/www/certbot
certbot:
image: certbot/certbot
volumes:
- ./data/certbot/conf:/etc/letsencrypt:rw
- ./data/certbot/www:/var/www/certbot:rw
this is my nginx conf file
server{
listen 80;
server_name loanportal.inforvio.in;
# proxy_pass http://43.205.233.133:8000;
root /var/www/certbot;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/loanportal.inforvio.in/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/loanportal.inforvio.in/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
proxy_pass http://loanportal.inforvio.in; #for demo purposes
This is what I see:
PORT    STATE  SERVICE
80/tcp  open   http
443/tcp closed https
all ports are open ALLTCP open
Your server redirects to port 443 which is REFUSING connections.
@385ms: Server response: HTTP 301 Moved Permanently
@385ms: Received redirect to https://portalloan.inforvio.in/.well-known/acme-challenge/letsdebug-test
@386ms: Dialing 35.154.100.196
@578ms: Experienced error: dial tcp 35.154.100.196:443: connect: connection refused
PORT    STATE  SERVICE
80/tcp  open   http
443/tcp closed https <<<<<<<< **This port needs to be accessible.**
in my server securitygroup i have enabled both http and https port
and my docker nginx webserver is running ,
bffb6b98d961 nginx:latest "/docker-entrypoint.…" 3 minutes ago Up 3 seconds 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp ubuntu-nginx-1
this is my nginx conatiner running status on this 35.154.100.196 host
Your site is not visible from my location. Can you see it? I am not a docker expert so I'll have to pass this thread on to someone more capable.
There has been a change:
PORT    STATE  SERVICE
80/tcp  closed http
Domain: portalloan.inforvio.in
Detail: 35.154.100.196: Invalid response from http://portalloan.inforvio.in/.well-known/acme-challenge/enpvTdSaFYLO4BmwWrW1HyQDFQbQSds2Bp65fKACjLE: 404
"404" error is better than "Connection refused" error.
So, progress is being made :wink:
I have two suggestions:
  • use the staging environment until all testing has been completed
  • verify the webroot being used
    [compare the path in the renewal config file with the root in the nginx config]
Presently I am seeing this from my IPv4 only location.
Just checking the URLs and the redirects.
$ curl -Ii http://portalrpa.inforvio.in/.well-known/acme-challenge/sometestfile
Server: awselb/2.0
Date: Wed, 24 May 2023 17:46:35 GMT
Content-Type: text/html
Content-Length: 134
Location: https://portalrpa.inforvio.in:443/.well-known/acme-challenge/sometestfile
$ curl -Ii https://portalrpa.inforvio.in:443/.well-known/acme-challenge/sometestfile
HTTP/2 503
server: awselb/2.0
date: Wed, 24 May 2023 17:46:46 GMT
content-type: text/html
content-length: 162
set-cookie: AWSALBTG=g325OlhEEmk3lXJ+RjJvHnoYa7FldeRDHS6FZq8y7MgrzasAsSrM8S6CKKZs9rPeyEGhENRqofzC8MxqfjlD44u0Ry8iIQBJPcOdiajATnzcdvrWCfNpWWx9okA1rBRHJJ668bDZeNTnEkEVoIX4YH7/3KtR8kKLa62eGZY1RqbfhLs0+HI=; Expires=Wed, 31 May 2023 17:46:46 GMT; Path=/
set-cookie: AWSALBTGCORS=g325OlhEEmk3lXJ+RjJvHnoYa7FldeRDHS6FZq8y7MgrzasAsSrM8S6CKKZs9rPeyEGhENRqofzC8MxqfjlD44u0Ry8iIQBJPcOdiajATnzcdvrWCfNpWWx9okA1rBRHJJ668bDZeNTnEkEVoIX4YH7/3KtR8kKLa62eGZY1RqbfhLs0+HI=; Expires=Wed, 31 May 2023 17:46:46 GMT; Path=/; SameSite=None; Secure
$ curl -Ii http://loanportal.inforvio.in/.well-known/acme-challenge/sometestfile
Server: awselb/2.0
Date: Wed, 24 May 2023 17:47:31 GMT
Content-Length: 134
Location: https://loanportal.inforvio.in:443/.well-known/acme-challenge/sometestfile
$ curl -Ii https://loanportal.inforvio.in:443/.well-known/acme-challenge/sometestfile
HTTP/2 503
server: awselb/2.0
date: Wed, 24 May 2023 17:47:41 GMT
content-length: 162
set-cookie: AWSALBTG=EbF8JshdOQF+OJqIzi1u5u9f2CzbSAzPlJWVYk40fSJwZvGb5s6yU4bTAlrEPMlJrysGfKthJoE9CIGykkDVX55rqvRLFCINyf1ZRWr7wb2+nUnEtk6sYwcWPsddph/JkYQtTOR9KC+hoJbgR0p3Cbrz82uONbnH7F9yQGdPYsuddBDflZk=; Expires=Wed, 31 May 2023 17:47:41 GMT; Path=/
set-cookie: AWSALBTGCORS=EbF8JshdOQF+OJqIzi1u5u9f2CzbSAzPlJWVYk40fSJwZvGb5s6yU4bTAlrEPMlJrysGfKthJoE9CIGykkDVX55rqvRLFCINyf1ZRWr7wb2+nUnEtk6sYwcWPsddph/JkYQtTOR9KC+hoJbgR0p3Cbrz82uONbnH7F9yQGdPYsuddBDflZk=; Expires=Wed, 31 May 2023 17:47:41 GMT; Path=/; SameSite=None; Secure
$ nmap -Pn -p80,443 portalrpa.inforvio.in
Starting Nmap 7.93 ( https://nmap.org ) at 2023-05-24 10:48 PDT
Nmap scan report for portalrpa.inforvio.in (52.66.189.239)
Host is up (0.24s latency).
Other addresses for portalrpa.inforvio.in (not scanned): 52.66.72.66 3.7.152.90
rDNS record for 52.66.189.239: ec2-52-66-189-239.ap-south-1.compute.amazonaws.com
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.62 seconds
$ nmap -Pn -p80,443 loanportal.inforvio.in
Nmap scan report for loanportal.inforvio.in (3.7.152.90)
Other addresses for loanportal.inforvio.in (not scanned): 52.66.72.66 52.66.189.239
rDNS record for 3.7.152.90: ec2-3-7-152-90.ap-south-1.compute.amazonaws.com
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.54 seconds
