Certbot certificate issue
l2.clik2.in
#!/bin/bash
if ! [ -x "$(command -v docker-compose)" ]; then
  echo 'Error: docker-compose is not installed.' >&2
  exit 1
fi
domains=(l2.clik2.in)
rsa_key_size=4096
data_path="./data/certbot"
email="ajith@loanwiser.in" # Adding a valid address is strongly recommended
staging=0 # Set to 1 if you're testing your setup to avoid hitting request limits
if [ -d "$data_path" ]; then
  read -p "Existing data found for $domains. Continue and replace existing certificate? (y/N) " decision
  if [ "$decision" != "Y" ] && [ "$decision" != "y" ]; then
    exit
  fi
fi
if [ ! -e "$data_path/conf/options-ssl-nginx.conf" ] || [ ! -e "$data_path/conf/ssl-dhparams.pem" ]; then
  echo "### Downloading recommended TLS parameters ..."
  mkdir -p "$data_path/conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot-nginx/certbot_nginx/_internal/tls_configs/options-ssl-nginx.conf > "$data_path/conf/options-ssl-nginx.conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot/certbot/ssl-dhparams.pem > "$data_path/conf/ssl-dhparams.pem"
  echo
fi
echo "### Creating dummy certificate for $domains ..."
path="/etc/letsencrypt/live/$domains"
mkdir -p "$data_path/conf/live/$domains"
docker-compose run --rm --entrypoint "\
  openssl req -x509 -nodes -newkey rsa:$rsa_key_size -days 1\
    -keyout '$path/privkey.pem' \
    -out '$path/fullchain.pem' \
    -subj '/CN=localhost'" certbot
echo
echo "### Starting nginx ..."
docker-compose up --force-recreate -d nginx
echo
echo "### Deleting dummy certificate for $domains ..."
  rm -Rf /etc/letsencrypt/live/$domains && \
  rm -Rf /etc/letsencrypt/archive/$domains && \
  rm -Rf /etc/letsencrypt/renewal/$domains.conf" certbot
echo
echo "### Requesting Let's Encrypt certificate for $domains ..."
#Join $domains to -d args
domain_args=""
for domain in "${domains[@]}"; do
  domain_args="$domain_args -d $domain"
done
# Select appropriate email arg
case "$email" in
  "") email_arg="--register-unsafely-without-email" ;;
  *) email_arg="--email $email" ;;
esac
# Enable staging mode if needed
if [ $staging != "0" ]; then staging_arg="--staging"; fi
  certbot certonly --webroot -w /var/www/certbot \
    $staging_arg \
    $email_arg \
    $domain_args \
    --rsa-key-size $rsa_key_size \
    --agree-tos \
    --force-renewal" certbot
echo
echo "### Reloading nginx ..."
docker-compose exec nginx nginx -s reload
Existing data found for l2.clik2.in. Continue and replace existing certificate? (y/N) y
### Creating dummy certificate for l2.clik2.in ...
Creating pygmy_certbot_run ... done
Generating a RSA private key
writing new private key to '/etc/letsencrypt/live/l2.clik2.in/privkey.pem'
Recreating pygmy_nginx_1 ... done
### Deleting dummy certificate for l2.clik2.in ...
### Requesting Let's Encrypt certificate for l2.clik2.in ...
Requesting a certificate for l2.clik2.in
  Domain: l2.clik2.in
  Type:   connection
  Detail: 43.205.233.133: Fetching http://l2.clik2.in/.well-known/acme-challenge/AOmz4MTA_ezQ6Tk7x07BhBHWGvOLWBof4z1B2hDF2KA: Connection refused
ERROR: 1
nginx
aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): latest
What a mess of a script. The issue should be with the aws firewall, though: @MikeMcQ is our resident expert.
Can't Understand what you are saying , When I generate certificate manually it works fine ,but i do it on docker it threws this kind of error
please edit your post and put three backticks before and after your script,
your script
Also, show me your docker-compose.yml the same way. I suspect you forgot to expose some ports.
my docker-compose file
version: '3'
services:
  database:
    image: postgres:11
    restart: always
    ports:
      - "5433:5432"
    volumes:
      - pgdata:/var/lib/postgresql/data
    environment:
      POSTGRES_PASSWORD: root
      POSTGRES_USER: root
      POSTGRES_DB: pygmy
  pygmy:
    image: amit19/pygmy
    restart: always
    build: .
    ports:
      - "9119:9119"
    links:
      - database
    environment:
      - DB_PASSWORD=root
      - DB_USER=root
      - DB_NAME=pygmy
      - DB_HOST=database
      - DB_PORT=5432
    volumes:
     - .:/pygmy
    command: gunicorn --log-file /var/log/pygmy/error_logs.log --access-logfile /var/log/pygmy/acclogs.log --log-level DEBUG --bind 0.0.0.0:9119 --workers 2 pygmy.rest.wsgi:app
    depends_on:
      - database
  pygmyui:
    image: amit19/pygmy
    restart: always
    build: .
    ports:
      - "8000:8000"
    links:
      - pygmy
    environment:
      - PYGMY_API_ADDRESS=pygmy
    command: sh -c "cd pygmyui && gunicorn --log-file /var/log/pygmy/uierror_logs.log --access-logfile /var/log/pygmy/uiacclogs.log --bind 0.0.0.0:8000 --workers 2 pygmyui.wsgi && cd .."
    depends_on:
      - pygmy
  nginx:
    image: nginx:1.15-alpine
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - ./data/nginx:/etc/nginx/conf.d
      - ./data/certbot/conf:/etc/letsencrypt
      - ./data/certbot/www:/var/www/certbot
  certbot:
    image: certbot/certbot
    volumes:
      - ./data/certbot/conf:/etc/letsencrypt:rw
      - ./data/certbot/www:/var/www/certbot:rw
volumes:
  pgdata:
please use the backticks :wink:
I don't even get an A/AAAA dns record for this. Is this on purpose?
I mapped this domain in Dns and the record type is A
$ curl --resolve l2.clik2.in:80:43.205.233.133 -IL http://l2.clik2.in/.well-known/acme-challenge/AOmz4MTA_ezQ6Tk7x07BhBHWGvOLWBof4z1B2hDF2KA
curl: (7) Failed to connect to l2.clik2.in port 80 after 281 ms: Connessione rifiutata
Are you filtering connections from foreign countries?
No....
its enable for all countries
Is your nginx running?
No I stopped.... can i run
You should try to run it, use the staging environment.
  Domain: l2.clik2.in
  Type:   connection
  Detail: 43.205.233.133: Fetching http://l2.clik2.in/.well-known/acme-challenge/bgHna2ev8OhuHuu69UqpCq0dbAZgxby9CqgARnt0Cz4: Connection refused
ERROR: 1
try to start nginx and nginx alone. docker compose start nginx I think.
while i start nginx
Creating pygmy_nginx_1 ... done
Attaching to pygmy_nginx_1
nginx_1 | 2022/10/12 10:25:28 [emerg] 1#1: "ssl_certificate" directive is not allowed here in /etc/nginx/conf.d/app.conf:22
nginx_1 | nginx: [emerg] "ssl_certificate" directive is not allowed here in /etc/nginx/conf.d/app.conf:22
pygmy_nginx_1 exited with code 1
this is my nginx conf file
    listen 80;
    server_name l2.clik2.in;
        proxy_pass http://43.205.233.133:8000;
    root /var/www/certbot;
    listen 443 ssl;
        proxy_pass http://43.205.233.133:8000; #for demo purposes
       ssl_certificate /etc/letsencrypt/live/l2.clik2.in/fullchain.pem;
       ssl_certificate_key /etc/letsencrypt/live/l2.clik2.in/privkey.pem;
       include /etc/letsencrypt/options-ssl-nginx.conf;
       ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
that looks like the issue. you cannot have the ssl_certificate directives in a location block. move them to the server block. :smiley:
thanks @9peppe your genius :heart_eyes: :heart_eyes:..........it's working nowww ......
Certificate is saved at: /etc/letsencrypt/live/l2.clik2.in/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/l2.clik2.in/privkey.pem
This certificate expires on 2023-01-10.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See https://certbot.org/renewal-setup for instructions.
 * Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
 * Donating to EFF:                    https://eff.org/donate-le
