My certbot installation is broken, and I am unable to fix it.
root@stage:~# certbot
An unexpected error occurred:
pkg_resources.VersionConflict: (certbot 0.31.0 (/usr/lib/python3/dist-packages), Requirement.parse(‘certbot>=0.34.0’))
Please see the logfile ‘/tmp/tmpbyuigqhc’ for more details.
The file ‘/tmp/tmpbyuigqhc’ contains this:
2019-07-11 10:55:42,014:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.31.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1335, in main
plugins = plugins_disco.PluginsRegistry.find_all()
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 206, in find_all
plugin_ep = PluginEntryPoint(entry_point)
File “/usr/lib/python3/dist-packages/certbot/plugins/disco.py”, line 52, in init
self.plugin_cls = entry_point.load()
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 2290, in load
self.require(*args, **kwargs)
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 2307, in require
items = working_set.resolve(reqs, env, installer)
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 854, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
2019-07-11 10:55:42,014:ERROR:certbot.log:An unexpected error occurred:
Probably my certbot installation got broken as part of fiddling with installing different certbot versions (perhaps even distributions) and certbot-auto.
Reinstalling certbot does not solve the issue.
Maybe certbot is wrongfully configured somehow, e.g. to use an invalid python installation?
I have installed certbot on several other servers using these commands and it works fine on all of them (because the certbot is not broken there).
The package manager reports a lot. Not sure if below is helpful.
root@stage:~# dpkg -l | grep -e certbot
ii certbot 0.31.0-1+ubuntu16.04.1+certbot+1 all automatically configure HTTPS using Let’s Encrypt
ii python-certbot-nginx 0.31.0-1+ubuntu16.04.1+certbot+1 all transitional dummy package
ii python3-acme 0.31.0-1+ubuntu16.04.1+certbot+1 all ACME protocol library for Python 3
ii python3-asn1crypto 0.22.0-2+ubuntu16.04.1+certbot+1 all Fast ASN.1 parser and serializer (Python 3)
ii python3-certbot 0.31.0-1+ubuntu16.04.1+certbot+1 all main library for certbot
ii python3-certbot-dns-cloudflare 0.23.0-1ubuntu0ppa1~ubuntu16.04.1 all Cloudflare DNS plugin for Certbot
ii python3-certbot-nginx 0.31.0-1+ubuntu16.04.1+certbot+1 all Nginx plugin for Certbot
ii python3-certifi 2017.4.17-2+ubuntu16.04.1+certbot+1 all root certificates for validating SSL certs and verifying TLS hosts (python3)
ii python3-cffi-backend 1.10.0-0.1+ubuntu16.04.1+certbot+1 amd64 Foreign Function Interface for Python 3 calling C code - runtime
ii python3-chardet 3.0.4-1+ubuntu16.04.1+certbot+2 all universal character encoding detector for Python3
ii python3-configargparse 0.11.0-1+certbot~xenial+1 all replacement for argparse with config files and environment variables (Python 3)
ii python3-configobj 5.0.6-2+ubuntu16.04.1+certbot+1 all simple but powerful config file reader and writer for Python 3
ii python3-cryptography 1.9-1+ubuntu16.04.1+certbot+2 amd64 Python library exposing cryptographic recipes and primitives (Python 3)
ii python3-future 0.15.2-4+ubuntu16.04.1+certbot+3 all Clean single-source support for Python 3 and 2 - Python 3.x
ii python3-idna 2.5-1+ubuntu16.04.1+certbot+1 all Python IDNA2008 (RFC 5891) handling (Python 3)
ii python3-josepy 1.1.0-2+ubuntu16.04.1+certbot+1 all JOSE implementation for Python 3.x
ii python3-ndg-httpsclient 0.4.2-1+certbot~xenial+1 all enhanced HTTPS support for httplib and urllib2 using PyOpenSSL for Python3
ii python3-openssl 17.3.0-1~0+ubuntu16.04.1+certbot+1 all Python 3 wrapper around the OpenSSL library
ii python3-parsedatetime 2.4-3+ubuntu16.04.1+certbot+3 all Python 3 module to parse human-readable date/time expressions
ii python3-pkg-resources 33.1.1-1+certbot~xenial+1 all Package Discovery and Resource Access using pkg_resources
ii python3-pyasn1 0.1.9-2+certbot~xenial+1 all ASN.1 library for Python (Python 3 module)
ii python3-requests 2.18.1-1+ubuntu16.04.1+certbot+1 all elegant and simple HTTP library for Python3, built for human beings
ii python3-requests-toolbelt 0.8.0-1+ubuntu16.04.1+certbot+1 all Utility belt for advanced users of python3-requests
ii python3-rfc3339 1.0-4+certbot~xenial+1 all parser and generator of RFC 3339-compliant timestamps (Python 3)
ii python3-setuptools 33.1.1-1+certbot~xenial+1 all Python3 Distutils Enhancements
ii python3-six 1.11.0-1+ubuntu16.04.1+certbot+1 all Python 2 and 3 compatibility library (Python 3 interface)
ii python3-urllib3 1.21.1-1+ubuntu16.04.1+certbot+1 all HTTP library with thread-safe connection pooling for Python3
ii python3-zope.component 4.3.0-1+ubuntu16.04.1+certbot+3 all Zope Component Architecture
ii python3-zope.hookable 4.0.4-4+ubuntu16.04.1+certbot+1 amd64 Hookable object support
ii python3-zope.interface 4.3.2-1+ubuntu16.04.1+certbot+1 amd64 Interfaces for Python3
It is indeed certbot 0.31.0 that I have installed. But where does this “Requirement.parse(‘certbot>=0.34.0’)” come from and why is it still here? I am guessing this is a leftover from a previous certbot installation that was not properly removed/purged when I uninstalled it.
root@stage:~# apt purge certbot
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following package was automatically installed and is no longer required:
python3-pyparsing
Use ‘apt autoremove’ to remove it.
The following packages will be REMOVED:
certbot* python-certbot-nginx* python3-certbot-nginx*
0 upgraded, 0 newly installed, 3 to remove and 1 not upgraded.
After this operation, 340 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database … 122559 files and directories currently installed.)
Removing python-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Removing python3-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Removing certbot (0.31.0-1+ubuntu16.04.1+certbot+1) …
Purging configuration files for certbot (0.31.0-1+ubuntu16.04.1+certbot+1) …
Processing triggers for man-db (2.7.5-1) …
root@stage:~# apt-get install python-certbot-nginx
The following additional packages will be installed:
certbot python3-certbot-nginx
Suggested packages:
python3-certbot-apache python-certbot-doc python-certbot-nginx-doc
The following NEW packages will be installed:
certbot python-certbot-nginx python3-certbot-nginx
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/64.2 kB of archives.
After this operation, 340 kB of additional disk space will be used.
Selecting previously unselected package certbot.
(Reading database … 122510 files and directories currently installed.)
Preparing to unpack …/certbot_0.31.0-1+ubuntu16.04.1+certbot+1_all.deb …
Unpacking certbot (0.31.0-1+ubuntu16.04.1+certbot+1) …
Selecting previously unselected package python3-certbot-nginx.
Preparing to unpack …/python3-certbot-nginx_0.31.0-1+ubuntu16.04.1+certbot+1_all.deb …
Unpacking python3-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Selecting previously unselected package python-certbot-nginx.
Preparing to unpack …/python-certbot-nginx_0.31.0-1+ubuntu16.04.1+certbot+1_all.deb …
Unpacking python-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Setting up certbot (0.31.0-1+ubuntu16.04.1+certbot+1) …
certbot.service is a disabled or a static unit, not starting it.
Setting up python3-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Setting up python-certbot-nginx (0.31.0-1+ubuntu16.04.1+certbot+1) …
Please see the logfile ‘/tmp/tmpwmteb61w’ for more details.
The problem here is the certbot-dns-cloudflare installation left over from pip. You can tell it’s from pip instead of certbot-auto or apt because it’s in /usr/local.
When Certbot runs, it’s searching your Python environment for any Certbot plugins, finding the Cloudflare plugin, and trying to load it which fails because it has unsatisfied dependencies.
Removing this plugin through pip or manually deleting these files should solve your problem.
