Certbot auto renewal problem
Hi all,
I have problems renewing my certificates. I hope you can help me a bit.
My domain is: www.ritchievink.com
Os: Ubuntu 16.04
host: linode
certbot version: 0.28.0
python version: 3.5.2
Logs
My standalone attempt:
    certbot certonly --standalone
(Alternatively, add a --installer flag. See https://eff.org/letsencrypt-plugins
 and "--help plugins" for more information.)
2021-11-08 08:20:21,600:DEBUG:certbot.main:certbot version: 0.28.0
2021-11-08 08:20:21,602:DEBUG:certbot.main:Arguments: ['--standalone', '-d', 'ritchievink.com', '-d', 'www.ritchievink.com']
2021-11-08 08:20:21,603:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2021-11-08 08:20:21,617:DEBUG:certbot.log:Root logging level set at 20
2021-11-08 08:20:21,618:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2021-11-08 08:20:21,619:DEBUG:certbot.plugins.selection:Requested authenticator standalone and installer None
2021-11-08 08:20:21,764:DEBUG:certbot.plugins.selection:Single candidate plugin: * standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot.plugins.standalone:Authenticator
Initialized: <certbot.plugins.standalone.Authenticator object at 0x7f686201d710>
Prep: True
2021-11-08 08:20:21,765:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.standalone.Authenticator object at 0x7f686201d710> and installer None
2021-11-08 08:20:21,765:INFO:certbot.plugins.selection:Plugins selected: Authenticator standalone, Installer None
2021-11-08 08:20:21,792:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(terms_of_service='https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf', new_authzr_uri='https://acme-v01.api.letsencrypt.org/acme/new-authz', body=Registration(contact=('mailto:ritchie46@gmail.com',), agreement='https://letsencrypt.org/documents/LE-SA-v1.1.1-August-1-2016.pdf', only_return_existing=None, status=None, terms_of_service_agreed=None, key=JWKRSA(key=<ComparableRSAKey(<cryptography.hazmat.backends.openssl.rsa._RSAPublicKey object at 0x7f6861f395f8>)>)), uri='https://acme-v01.api.letsencrypt.org/acme/reg/4860580'), ecf4c70bb6ee06bf0d82567dd36401c1, Meta(creation_host='laizen', creation_dt=datetime.datetime(2016, 10, 3, 20, 14, 58, tzinfo=<UTC>)))>
2021-11-08 08:20:21,794:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2021-11-08 08:20:21,797:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org
2021-11-08 08:20:22,055:DEBUG:certbot.log:Exiting abnormally:
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 560, in urlopen
    body=body, headers=headers)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in _validate_conn
    conn.connect()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 252, in connect
    ssl_version=resolved_ssl_version)
  File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 305, in ssl_wrap_socket
    return context.wrap_socket(sock, server_hostname=server_hostname)
  File "/usr/lib/python3.5/ssl.py", line 377, in wrap_socket
    _context=self)
  File "/usr/lib/python3.5/ssl.py", line 752, in __init__
    self.do_handshake()
  File "/usr/lib/python3.5/ssl.py", line 988, in do_handshake
    self._sslobj.do_handshake()
  File "/usr/lib/python3.5/ssl.py", line 633, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 376, in send
    timeout=timeout
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 589, in urlopen
    raise SSLError(e)
requests.packages.urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
  File "/usr/bin/certbot", line 11, in <module>
    load_entry_point('certbot==0.28.0', 'console_scripts', 'certbot')()
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 1340, in main
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 1209, in certonly
    le_client = _init_le_client(config, auth, installer)
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 611, in _init_le_client
    return client.Client(config, acc, authenticator, installer, acme=acme)
  File "/usr/lib/python3/dist-packages/certbot/client.py", line 248, in __init__
    acme = acme_from_config_key(config, self.account.key, self.account.regr)
  File "/usr/lib/python3/dist-packages/certbot/client.py", line 51, in acme_from_config_key
    return acme_client.BackwardsCompatibleClientV2(net, key, config.server)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 763, in __init__
    directory = messages.Directory.from_json(net.get(server).json())
  File "/usr/lib/python3/dist-packages/acme/client.py", line 1097, in get
    self._send_request('GET', url, **kwargs), content_type=content_type)
  File "/usr/lib/python3/dist-packages/acme/client.py", line 1046, in _send_request
    response = self.session.request(method, url, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 468, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 576, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 447, in send
    raise SSLError(e, request=request)
requests.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:645)
2021-11-08 08:20:22,057:ERROR:certbot.log:An unexpected error occurred:
Additional info
curl -X GET -I -m 10 https://acme-v02.api.letsencrypt.org/directory
curl: (60) server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
More details here: curl - SSL CA Certificates
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
python -c "import requests; print(requests.get(‘https://acme-v02.api.letsencrypt.org/directory’).text)"
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in validate_conn
conn.connect()
_context=self)
File "/usr/lib/python3.5/ssl.py", line 752, in init
self.do_handshake()
timeout=timeout
raise SSLError(e)
File "", line 1, in
File "/usr/lib/python3/dist-packages/requests/api.py", line 67, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 53, in request
return session.request(method=method, url=url, **kwargs)
Following these steps helped:
