Here please find the logs below:
Description: Nginx Web Server plugin
Interfaces: Installer, Authenticator, Plugin
Entry point: nginx = certbot_nginx._internal.configurator:NginxConfigurator
Initialized: <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7fe505d37b20>
Prep: True
2022-09-07 10:51:43,284:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7fe505d37b20> and installer <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7fe505d37b20>
2022-09-07 10:51:43,284:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator nginx, Installer nginx
2022-09-07 10:51:43,298:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/41931791', new_authzr_uri=None, terms_of_service=None), 02e4272d6bd47cab8bc76500664baa6d, Meta(creation_dt=datetime.datetime(2018, 9, 11, 18, 27, 53, tzinfo=<UTC>), creation_host='ipc-da-web-2-prod.veriday.inc', register_to_eff=None))>
2022-09-07 10:51:43,299:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2022-09-07 10:51:43,301:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2022-09-07 10:51:43,492:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 672
2022-09-07 10:51:43,493:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 07 Sep 2022 10:51:43 GMT
Content-Length: 672
X-Frame-Options: DENY
"a1bWJprq0Xg": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017-w-v1.3-notice.pdf",
2022-09-07 10:52:26,890:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for janetpringle.ca
2022-09-07 10:58:32,304:DEBUG:certbot.crypto_util:Generating RSA key (2048 bits): /etc/letsencrypt/keys/45820_key-certbot.pem
2022-09-07 11:04:43,651:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/45810_csr-certbot.pem
2022-09-07 11:04:43,652:DEBUG:acme.client:Requesting fresh nonce
2022-09-07 11:04:43,652:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2022-09-07 11:04:43,653:DEBUG:urllib3.connectionpool:Resetting dropped connection: acme-v02.api.letsencrypt.org
2022-09-07 11:04:43,801:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2022-09-07 11:04:43,801:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 07 Sep 2022 11:04:43 GMT
Replay-Nonce: 0102b5cBulpQ8XsJfWu754pgKeg_agtrS8AtnE-h4x9NlUI
2022-09-07 11:04:43,802:DEBUG:acme.client:Storing nonce: 0102b5cBulpQ8XsJfWu754pgKeg_agtrS8AtnE-h4x9NlUI
2022-09-07 11:04:43,802:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "janetpringle.ca"\n }\n ]\n}'
2022-09-07 11:04:43,803:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDE5MzE3OTEiLCAibm9uY2UiOiAiMDEwMmI1Y0J1bHBROFhzSmZXdTc1NHBnS2VnX2FndHJTOEF0bkUtaDR4OU5sVUkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
"signature": "AvCBYMGhwZcpye0UxkJTxAaQkzhqeB-HAr52xN8-EKgZHVnKmT1hPltiwUZZ7y4Tv464XK-Njru9T4TEkfcMoq7mGzUpTxqk75TIExZbwAVvTGTX6PKAx3mHg30qqYALjdAowglnBaxtIJ5wwkKQ03Xu3tlxzS9KupZcdFJohtsXiHRsfZxOkcg5CweNJAWiXSo5YrDcsux7j8X1uUzRIagCx0AMAS1D-cPZpCb4cnVfk2d54pnF4-tWP3gCFzbG1sr-TRivZg7-Hpo0ArV6pv50K2U0CLsA_dJg4cVbLGbFmg27tBP2KFD00f6dmNWUlBXxZN91e2tEZB5mhmu2Lg",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImphbmV0cHJpbmdsZS5jYSIKICAgIH0KICBdCn0"
2022-09-07 11:04:44,060:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 339
2022-09-07 11:04:44,061:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Date: Wed, 07 Sep 2022 11:04:44 GMT
Content-Length: 339
Boulder-Requester: 41931791
Location: https://acme-v02.api.letsencrypt.org/acme/order/41931791/123316025657
Replay-Nonce: 01022OB5H2iKIe-1xj_9nmRE5efJONEvwL4a8C_NAyDrM5Y
"status": "pending",
"expires": "2022-09-14T10:50:38Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/150716602377"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/41931791/123316025657"
2022-09-07 11:04:44,061:DEBUG:acme.client:Storing nonce: 01022OB5H2iKIe-1xj_9nmRE5efJONEvwL4a8C_NAyDrM5Y
2022-09-07 11:04:44,061:DEBUG:acme.client:JWS payload:
b''
2022-09-07 11:04:44,062:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/150716602377:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDE5MzE3OTEiLCAibm9uY2UiOiAiMDEwMjJPQjVIMmlLSWUtMXhqXzlubVJFNWVmSk9ORXZ3TDRhOENfTkF5RHJNNVkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzE1MDcxNjYwMjM3NyJ9",
"signature": "qHZi7LHZvtRnV7RIXuHU7Y8ImJwx4Ws3j11ivTwWbUovg5gzJJ2h49izWzwPBrIx1z6N1M3rkkngkMAMA9N1d4XNGEZpA3gIjGOnFC8GyKWg3k_8xoHZTi_AxU-a0-_Zj5T3gbsig3KrmMGLHP6DkD7Sa0Y4kdL5OhC24O7JeO2kQVqDakYu7fGNCWgyFm3vC3OFKS-LoFXe6vedQD6cqp2_8IxZYFMB7U0VT7W4jnnjH2RSbIXMD8dP67HbkxeBcs4jX4GuQq6ClNopx_5Dpbptl1hmMdmys9L8BIeA8jG-1Ko6Hz_wg2dvcZ_a4EKYl199ifDIFkZoGcf7t2Xsgw",
"payload": ""
2022-09-07 11:04:44,122:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/150716602377 HTTP/1.1" 200 799
2022-09-07 11:04:44,122:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 799
Replay-Nonce: 0102Z6ETow33cuZ7X6Zhh5lKU0Vfh79RBX9TbBMZKD-btu0
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/150716602377/f0dDlA",
"token": "iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/150716602377/Ue2Pbw",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/150716602377/qP3ABA",
2022-09-07 11:04:44,122:DEBUG:acme.client:Storing nonce: 0102Z6ETow33cuZ7X6Zhh5lKU0Vfh79RBX9TbBMZKD-btu0
2022-09-07 11:04:44,123:INFO:certbot._internal.auth_handler:Performing the following challenges:
2022-09-07 11:04:44,123:INFO:certbot._internal.auth_handler:http-01 challenge for janetpringle.ca
2022-09-07 11:04:45,247:DEBUG:certbot_nginx._internal.http_01:Generated server block:
2022-09-07 11:04:45,254:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/99-customdomain-template.conf
2022-09-07 11:04:45,255:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/davidsimmons.ca.conf
2022-09-07 11:04:45,255:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sterlingwealth.ca.conf
2022-09-07 11:04:45,255:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financialchoices.ca.conf
2022-09-07 11:04:45,255:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thesimundsonteam.ca.conf
2022-09-07 11:04:45,256:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/carrefour-solutions.com.conf
2022-09-07 11:04:45,256:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcguelph.ca.conf
2022-09-07 11:04:45,256:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thomsonnixonfinancial.ca.conf
2022-09-07 11:04:45,256:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/peace-of-mind.ca.conf
2022-09-07 11:04:45,256:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/asgaardcapital.ca.conf
2022-09-07 11:04:45,257:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/webbandassociates.ca.conf
2022-09-07 11:04:45,257:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/converywealth.com.conf
2022-09-07 11:04:45,257:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/marcoberardi.ca.conf
2022-09-07 11:04:45,257:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/caseycerson.ca.conf
2022-09-07 11:04:45,257:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/whitby.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,258:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thetwoheyteam.ca.conf
2022-09-07 11:04:45,258:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/hennigarplanning.com.conf
2022-09-07 11:04:45,258:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/hollylangley.ca.conf
2022-09-07 11:04:45,258:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipckawarthalakes.ca.conf
2022-09-07 11:04:45,258:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/aafinancialsolution.com.conf
2022-09-07 11:04:45,259:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dennisfedor.ca.conf
2022-09-07 11:04:45,259:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,259:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lyngreer.ca.conf
2022-09-07 11:04:45,259:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stageplanning.ca.conf
2022-09-07 11:04:45,260:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/spencerfinancial.ca.conf
2022-09-07 11:04:45,260:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/da-advisor-robots.rules
2022-09-07 11:04:45,260:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/retirewithipc.com.conf
2022-09-07 11:04:45,260:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/Michaelmartin.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,260:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcbrantford.com.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dereklanting.ca.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rejstringer.ca.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/enhancedwealth.ca.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ayrfinancial.ca.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bhdfinancial.ca.conf
2022-09-07 11:04:45,261:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/fischer-financial.ca.conf
2022-09-07 11:04:45,262:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/corinnelaflamme.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,262:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thearchitect4wealth.ca.conf
2022-09-07 11:04:45,262:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipclakeshore.com.conf
2022-09-07 11:04:45,262:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcadvisor.com.conf
2022-09-07 11:04:45,262:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/luofinancial.com.conf
2022-09-07 11:04:45,263:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keyinvestment.ca.conf
2022-09-07 11:04:45,263:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/guelphfinancial.com.conf
2022-09-07 11:04:45,263:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/johnsoutsos.com.conf
2022-09-07 11:04:45,263:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipckenora.ca.conf
2022-09-07 11:04:45,263:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planningprofessionals.ca.conf
2022-09-07 11:04:45,264:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/monetarygrowth.net.conf
2022-09-07 11:04:45,264:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/jwmfinancial.com.conf
2022-09-07 11:04:45,264:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/joewong.ca.conf
2022-09-07 11:04:45,264:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/janetpringle.ca.conf
2022-09-07 11:04:45,264:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/cynthiamariani.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,265:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bowescapital.com.conf
2022-09-07 11:04:45,265:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/alexhargrave.com.conf
2022-09-07 11:04:45,265:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/randywright.ca.conf
2022-09-07 11:04:45,265:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/cevawealth.com.conf
2022-09-07 11:04:45,265:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/salmonarmipc.ca.conf
2022-09-07 11:04:45,266:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rmsinvestmentgroup.ca.conf
2022-09-07 11:04:45,266:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/leclercfinancial.ca.conf
2022-09-07 11:04:45,266:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lakesidefinancialplanning.com.conf
2022-09-07 11:04:45,266:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/teammontcalm.ca.conf
2022-09-07 11:04:45,267:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sabatinifinancial.com.conf
2022-09-07 11:04:45,267:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/portdalhousiefinancial.com.conf
2022-09-07 11:04:45,267:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/laurinfinancial.com.conf
2022-09-07 11:04:45,267:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipchuntclub.ca.conf
2022-09-07 11:04:45,267:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/aynsleylavergne.com.conf
2022-09-07 11:04:45,268:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/knovak.ca.conf
2022-09-07 11:04:45,268:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/yourlifericher.com.conf
2022-09-07 11:04:45,268:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/turlockwealthmanagement.com.conf
2022-09-07 11:04:45,268:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bartleyteam.com.conf
2022-09-07 11:04:45,268:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipccomox.ca.conf
2022-09-07 11:04:45,269:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/whitewaterfinancialinvestmentservices.ca.conf
2022-09-07 11:04:45,269:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/chriskorteipc.ca.conf
2022-09-07 11:04:45,269:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/pictafinancial.com.conf
2022-09-07 11:04:45,269:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipckingston.com.conf
2022-09-07 11:04:45,269:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ottawa.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,270:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/peter-tavener.com.conf
2022-09-07 11:04:45,270:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/corepg.ca.conf
2022-09-07 11:04:45,270:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcmontreal.ca.conf
2022-09-07 11:04:45,270:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sfcr.ca.conf
2022-09-07 11:04:45,270:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/burtonfinancial.com.conf
2022-09-07 11:04:45,271:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/darrenotto.com.conf
2022-09-07 11:04:45,271:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thesmithteam.ca.conf
2022-09-07 11:04:45,271:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mattandrob.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,271:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/kingston.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,271:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keithjones.ca.conf
2022-09-07 11:04:45,272:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/Robertmclntosh.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,272:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rwlfinancial.ca.conf
2022-09-07 11:04:45,272:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcc-calgary.com.conf
2022-09-07 11:04:45,272:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipchanna.ca.conf
2022-09-07 11:04:45,272:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/fortune-formula.com.conf
2022-09-07 11:04:45,273:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/discovery-financial.ca.conf
2022-09-07 11:04:45,273:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thedaviesmoffatteam.com.conf
2022-09-07 11:04:45,273:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ronaldmackillop.ca.conf
2022-09-07 11:04:45,273:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dswm.ca.conf
2022-09-07 11:04:45,273:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/yourdreamourcommitment.com.conf
2022-09-07 11:04:45,274:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/12-customdomains-redirect.conf
2022-09-07 11:04:45,274:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/peterborough.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,274:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/theplanners.ca.conf
2022-09-07 11:04:45,274:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/braleyadvisors-ipc.com.conf
2022-09-07 11:04:45,274:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/gicandassociates.com.conf
2022-09-07 11:04:45,275:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealthmanagementadvisor.ca.conf
2022-09-07 11:04:45,275:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcottawa.com.conf
2022-09-07 11:04:45,275:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bobmetcalfe.com.conf
2022-09-07 11:04:45,275:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/barryfitkowski.ca.conf
2022-09-07 11:04:45,275:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/fraserfinancialkamloops.com.conf
2022-09-07 11:04:45,276:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rroby.ca.conf
2022-09-07 11:04:45,276:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/goldleaffinancialgroup.com.conf
2022-09-07 11:04:45,276:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcs-commonsense.com.conf
2022-09-07 11:04:45,276:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcna.ca.conf
2022-09-07 11:04:45,276:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/randymckay.ca.conf
2022-09-07 11:04:45,277:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/omaripc.ca.conf
2022-09-07 11:04:45,277:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/clientcentricfinancial.com.conf
2022-09-07 11:04:45,277:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcwaterloo.ca.conf
2022-09-07 11:04:45,277:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/00-digitalagent.conf
2022-09-07 11:04:45,277:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/milton.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,278:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/gestionpriveeaaa.ca.conf
2022-09-07 11:04:45,278:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/hafinancial.com.conf
2022-09-07 11:04:45,278:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/liptonfinancial.ca.conf
2022-09-07 11:04:45,278:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcburlington.ca.conf
2022-09-07 11:04:45,278:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/blueskylastingwealth.com.conf
2022-09-07 11:04:45,279:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/myfinancialpilot.ca.conf
2022-09-07 11:04:45,279:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcniagara.ca.conf
2022-09-07 11:04:45,279:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keystonewealth.ca.conf
2022-09-07 11:04:45,279:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcpicton.com.conf
2022-09-07 11:04:45,279:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipckitchener.ca.conf
2022-09-07 11:04:45,280:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/nancypike.com.conf
2022-09-07 11:04:45,280:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/ipc-ro-fix.custom
2022-09-07 11:04:45,280:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lhg-inc.com.conf
2022-09-07 11:04:45,280:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/anthonydellarocca.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,280:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealthstrategies.ca.conf
2022-09-07 11:04:45,281:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/crestmarkfinancial.com.conf
2022-09-07 11:04:45,281:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/01-digitalagent.conf
2022-09-07 11:04:45,281:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/prosperityplan.ca.conf
2022-09-07 11:04:45,281:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ridingteam.ca.conf
2022-09-07 11:04:45,281:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/retirehappysooner.ca.conf
2022-09-07 11:04:45,282:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rickdavid.ca.conf
2022-09-07 11:04:45,282:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mwfi.ca.conf
2022-09-07 11:04:45,282:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mansfieldprivatecounsel.com.conf
2022-09-07 11:04:45,282:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stwealth.com.conf
2022-09-07 11:04:45,282:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/cottylaptev.com.conf
2022-09-07 11:04:45,283:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealthpartners.ca.conf
2022-09-07 11:04:45,283:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ms-ipc.ca.conf
2022-09-07 11:04:45,283:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/silvermaplefinancial.ca.conf
2022-09-07 11:04:45,283:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/chauhan.ca.conf
2022-09-07 11:04:45,283:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/legacywealthmanagement.com.conf
2022-09-07 11:04:45,284:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ckmfinancial.ca.conf
2022-09-07 11:04:45,284:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcsecuritiespickering.com.conf
2022-09-07 11:04:45,284:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipc-victoria.ca.conf
2022-09-07 11:04:45,284:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/richandres.com.conf
2022-09-07 11:04:45,284:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lockwealthadvisors.ca.conf
2022-09-07 11:04:45,285:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/myipc.ca.conf
2022-09-07 11:04:45,285:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipc-opes.com.conf
2022-09-07 11:04:45,285:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/craigfinancial.ca.conf
2022-09-07 11:04:45,285:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sawyerandassociates.ca.conf
2022-09-07 11:04:45,285:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bordercityfinancial.com.conf
2022-09-07 11:04:45,286:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/redsell-seguin.com.conf
2022-09-07 11:04:45,286:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/investwithmark.ca.conf
2022-09-07 11:04:45,286:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/oakstonewealth.ca.conf
2022-09-07 11:04:45,286:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/perspectivethroughplanning.ca.conf
2022-09-07 11:04:45,286:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lhfinancial.ca.conf
2022-09-07 11:04:45,287:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dereckslattery.ca.conf
2022-09-07 11:04:45,287:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lakesidewealthmanagement.ca.conf
2022-09-07 11:04:45,287:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/advicoipc.ca.conf
2022-09-07 11:04:45,287:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcteamooi.com.conf
2022-09-07 11:04:45,287:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/reithinvestments.ca.conf
2022-09-07 11:04:45,288:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/jonesteam.ca.conf
2022-09-07 11:04:45,288:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mikedunn.ca.conf
2022-09-07 11:04:45,288:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/solutionsaroundyou.com.conf
2022-09-07 11:04:45,288:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/tonysantoro.com.conf
2022-09-07 11:04:45,288:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/uptownwealthmanagement.com.conf
2022-09-07 11:04:45,289:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/therightrelationship.com.conf
2022-09-07 11:04:45,289:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipc-edmonton-central.com.conf
2022-09-07 11:04:45,289:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/kenvanderlaan.com.conf
2022-09-07 11:04:45,289:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/tedtwoheyipc.com.conf
2022-09-07 11:04:45,289:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sydneyfinancial.ca.conf
2022-09-07 11:04:45,290:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/chapmanwealth.ca.conf
2022-09-07 11:04:45,290:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-broken-liferay-paths.custom
2022-09-07 11:04:45,290:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/watermarkfinancial.ca.conf
2022-09-07 11:04:45,290:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rachmasplanning.com.conf
2022-09-07 11:04:45,290:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mae-claire.com.conf
2022-09-07 11:04:45,291:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/janssensfinancial.com.conf
2022-09-07 11:04:45,291:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financialframework.ca.conf
2022-09-07 11:04:45,291:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dnorton.com.conf
2022-09-07 11:04:45,291:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/horizoncapital.ca.conf
2022-09-07 11:04:45,291:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcgaudreau.com.conf
2022-09-07 11:04:45,292:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/vdkfinancial.com.conf
2022-09-07 11:04:45,292:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/fnwm.ca.conf
2022-09-07 11:04:45,292:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/advice-first.ca.conf
2022-09-07 11:04:45,292:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/derekirwinlewis.ca.conf
2022-09-07 11:04:45,292:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lifetrekfinancialgroup.com.conf
2022-09-07 11:04:45,293:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mgmwealthgroup.ca.conf
2022-09-07 11:04:45,293:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rizzutofinancial.ca.conf
2022-09-07 11:04:45,293:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipclondon.com.conf
2022-09-07 11:04:45,293:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rankinricewealth.com.conf
2022-09-07 11:04:45,293:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wynnewealth.ca.conf
2022-09-07 11:04:45,294:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dibrinawealth.com.conf
2022-09-07 11:04:45,294:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcgreaterniagara.com.conf
2022-09-07 11:04:45,294:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-custom-https-domain.custom
2022-09-07 11:04:45,294:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/empeyteam.com.conf
2022-09-07 11:04:45,294:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bayswaterwealth.ca.conf
2022-09-07 11:04:45,295:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/goodwealth.ca.conf
2022-09-07 11:04:45,295:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/familyfirstadvisors.ca.conf
2022-09-07 11:04:45,295:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mfcecutti.ca.conf
2022-09-07 11:04:45,295:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcewealthreport.com.conf
2022-09-07 11:04:45,295:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcsoo.ca.conf
2022-09-07 11:04:45,296:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/markgalarnyk.ca.conf
2022-09-07 11:04:45,296:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/Richardtaylor.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,296:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/pauljvaneyk.com.conf
2022-09-07 11:04:45,296:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/impactam.ca.conf
2022-09-07 11:04:45,296:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/michaelcollymore.com.conf
2022-09-07 11:04:45,297:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/djohnstone.ca.conf
2022-09-07 11:04:45,297:DEBUG:certbot.reverter:Creating backup of /etc/nginx/mime.types
2022-09-07 11:04:45,297:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcthorpeteam.org.conf
2022-09-07 11:04:45,297:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/midtownipc.com.conf
2022-09-07 11:04:45,297:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/stub-status.conf
2022-09-07 11:04:45,298:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sukhi.ca.conf
2022-09-07 11:04:45,298:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipc-royaloak.com.conf
2022-09-07 11:04:45,298:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcniagarafalls.ca.conf
2022-09-07 11:04:45,298:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/annickbrebner.ca.conf
2022-09-07 11:04:45,298:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcwealthwatch.ca.conf
2022-09-07 11:04:45,299:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/patmagliaro.com.conf
2022-09-07 11:04:45,299:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcmississauga.com.conf
2022-09-07 11:04:45,299:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/valaniteam.com.conf
2022-09-07 11:04:45,299:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dunphymolloy.com.conf
2022-09-07 11:04:45,299:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/veracityfinancial.ca.conf
2022-09-07 11:04:45,300:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/theleroygroup.com.conf
2022-09-07 11:04:45,300:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ejmfinancial.ca.conf
2022-09-07 11:04:45,300:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/herbbraley.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,300:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/clientfirstgroup.ca.conf
2022-09-07 11:04:45,300:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/nextstepsplanning.ca.conf
2022-09-07 11:04:45,301:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcoakville.com.conf
2022-09-07 11:04:45,301:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/leobonomi.com.conf
2022-09-07 11:04:45,301:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bickadvisors.ca.conf
2022-09-07 11:04:45,301:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipccwoodstock.on.ca.conf
2022-09-07 11:04:45,301:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/tkwm.ca.conf
2022-09-07 11:04:45,302:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/moneysmartipc.com.conf
2022-09-07 11:04:45,302:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/groomefinancial.com.conf
2022-09-07 11:04:45,302:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/theglenisteam.com.conf
2022-09-07 11:04:45,302:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/Jeangerardcauchon.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,302:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcsmanitoba.com.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rongraham.ca.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/cowenteam.com.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealthyplanning.com.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/winnipeg.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lynleydavidson.ca.conf
2022-09-07 11:04:45,303:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/yourfinancialcoach.ca.conf
2022-09-07 11:04:45,304:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcwaterloo.com.conf
2022-09-07 11:04:45,304:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/leeterryfinancialgroup.com.conf
2022-09-07 11:04:45,304:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wpg-plan.ca.conf
2022-09-07 11:04:45,304:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcmoosejaw.com.conf
2022-09-07 11:04:45,304:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/irelandfinancialinc.com.conf
2022-09-07 11:04:45,305:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcleamington.com.conf
2022-09-07 11:04:45,305:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/matthewvalenti.ca.conf
2022-09-07 11:04:45,305:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keillandassociates.com.conf
2022-09-07 11:04:45,305:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thetavenerteam.com.conf
2022-09-07 11:04:45,305:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wisemoneywithclaudio.com.conf
2022-09-07 11:04:45,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planningyourpeaceofmind.ca.conf
2022-09-07 11:04:45,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financialpages.ca.conf
2022-09-07 11:04:45,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wisemoneychoices.ca.conf
2022-09-07 11:04:45,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipccalgarywest.ca.conf
2022-09-07 11:04:45,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lankfinancial.com.conf
2022-09-07 11:04:45,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/allistonfinancial.com.conf
2022-09-07 11:04:45,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/hansonfinancial.ca.conf
2022-09-07 11:04:45,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mnfinancial.ca.conf
2022-09-07 11:04:45,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wrightteam.ca.conf
2022-09-07 11:04:45,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/jimtodd.ca.conf
2022-09-07 11:04:45,308:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planivest.com.conf
2022-09-07 11:04:45,308:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/conseilprivemansfield.com.conf
2022-09-07 11:04:45,308:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/abbottwealth.com.conf
2022-09-07 11:04:45,308:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rvanandel.com.conf
2022-09-07 11:04:45,308:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/northwoodfinancial.ca.conf
2022-09-07 11:04:45,309:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ardillfinancial.com.conf
2022-09-07 11:04:45,309:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/smartwealthadvice.ca.conf
2022-09-07 11:04:45,309:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lifeplanfinancial.ca.conf
2022-09-07 11:04:45,309:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/zacharyrosen.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,309:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/da-temp-advisor-robots.rules
2022-09-07 11:04:45,310:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/iisottawa.ca.conf
2022-09-07 11:04:45,310:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/krismississauga.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,310:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lscottipc.ca.conf
2022-09-07 11:04:45,310:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planyourwealth.ca.conf
2022-09-07 11:04:45,310:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcplanning.com.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/blainchiavarini.com.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/vonstackelberg.ca.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/agwealth.ca.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thematheisteam.ca.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipctannergroup.ca.conf
2022-09-07 11:04:45,311:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/marvens.ca.conf
2022-09-07 11:04:45,312:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/westendwealth.com.conf
2022-09-07 11:04:45,312:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planningforyou.ca.conf
2022-09-07 11:04:45,312:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/djohnsoninvestments.com.conf
2022-09-07 11:04:45,312:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/johnschneider.ca.conf
2022-09-07 11:04:45,312:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-rewrite.custom
2022-09-07 11:04:45,313:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stephenmonaghanwealth.com.conf
2022-09-07 11:04:45,313:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/makinglifelesstaxing.ca.conf
2022-09-07 11:04:45,313:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keizer-nicholson.com.conf
2022-09-07 11:04:45,313:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/franciscofonseca.ca.conf
2022-09-07 11:04:45,313:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/angelodeangelis.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,314:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/tbirtleyipc.ca.conf
2022-09-07 11:04:45,314:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dswminvest.com.conf
2022-09-07 11:04:45,314:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/steedenfinancial.co.conf
2022-09-07 11:04:45,314:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/leifsofinancial.ca.conf
2022-09-07 11:04:45,314:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/marymanson.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,315:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-locations.custom
2022-09-07 11:04:45,315:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/myfinancialplanningteam.com.conf
2022-09-07 11:04:45,315:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lilliefinancial.com.conf
2022-09-07 11:04:45,315:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/autuscapital.ca.conf
2022-09-07 11:04:45,315:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keepingyouontrack.com.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/diversicomarcolin.com.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipclom.com.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/pensionspecialists.ca.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/frezellteam.com.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financeforlife.ca.conf
2022-09-07 11:04:45,316:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/pellegrinifinancial.com.conf
2022-09-07 11:04:45,317:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bobsplanning.com.conf
2022-09-07 11:04:45,317:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/finabco.com.conf
2022-09-07 11:04:45,317:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-ipc.custom
2022-09-07 11:04:45,317:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stevepenney.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,317:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/thewealtharchitect.ca.conf
2022-09-07 11:04:45,318:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/hwealthgroup.com.conf
2022-09-07 11:04:45,318:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealth-strategies.net.conf
2022-09-07 11:04:45,318:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mississaugairoc.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,318:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bluemountainwealth.ca.conf
2022-09-07 11:04:45,318:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/foxfinancial.ca.conf
2022-09-07 11:04:45,319:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcplan.com.conf
2022-09-07 11:04:45,319:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mclarkefinancial.com.conf
2022-09-07 11:04:45,319:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/benewealthpcg.com.conf
2022-09-07 11:04:45,319:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/gfak.ca.conf
2022-09-07 11:04:45,319:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/goodwealthfinancial.ca.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bradfordfinancial.org.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/briggsfinancial.ca.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/fraserfinancialabbotsford.com.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/harbourfinancial-ipc.ca.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/sandraleonardelli.com.conf
2022-09-07 11:04:45,320:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipcmilton.ca.conf
2022-09-07 11:04:45,321:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financial-equilibrium.ca.conf
2022-09-07 11:04:45,321:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stonewallfinancialservices.ca.conf
2022-09-07 11:04:45,321:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mewiebe.com.conf
2022-09-07 11:04:45,321:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/stonecitywealth.com.conf
2022-09-07 11:04:45,321:DEBUG:certbot.reverter:Creating backup of /etc/nginx/conf.d/nginx-temp-custom-domain.custom
2022-09-07 11:04:45,322:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/anna-ottawa.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,322:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planyourdream.ca.conf
2022-09-07 11:04:45,322:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/caroltichelman.ca.conf
2022-09-07 11:04:45,322:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/rickumbrio.ca.conf
2022-09-07 11:04:45,322:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipchh.ca.conf
2022-09-07 11:04:45,323:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/teampietras.ca.conf
2022-09-07 11:04:45,323:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/pointe-claire.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,323:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/keywealth.ca.conf
2022-09-07 11:04:45,323:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ufirstwealth.ca.conf
2022-09-07 11:04:45,323:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/spangaro.ca.conf
2022-09-07 11:04:45,324:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipclangley.com.conf
2022-09-07 11:04:45,324:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/canhealthfinancial.com.conf
2022-09-07 11:04:45,324:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/lifecoachfinancial.com.conf
2022-09-07 11:04:45,324:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/wealthbenefits.ca.conf
2022-09-07 11:04:45,324:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/erveninvestments.com.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/bradfordwealth.ca.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/retire-sooner.org.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dennisfinancial.net.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/tannermississauga.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/leemosley.com.conf
2022-09-07 11:04:45,325:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/gooderteam.com.conf
2022-09-07 11:04:45,326:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/glenabbeyfinancial.com.conf
2022-09-07 11:04:45,326:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/andersonplanning.ca.conf
2022-09-07 11:04:45,326:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/billbliss.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,326:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/howetoplan.com.conf
2022-09-07 11:04:45,326:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/zoretich.com.conf
2022-09-07 11:04:45,327:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/planfirst.ca.conf
2022-09-07 11:04:45,327:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/gusq.com.conf
2022-09-07 11:04:45,327:DEBUG:certbot.reverter:Creating backup of /etc/nginx/nginx.conf
2022-09-07 11:04:45,327:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/financialfoundations.ca.conf
2022-09-07 11:04:45,327:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/teamgimas.ca.conf
2022-09-07 11:04:45,328:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/dwandersonconsulting.ca.conf
2022-09-07 11:04:45,328:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/milsomfinancial.com.conf
2022-09-07 11:04:45,328:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/penneymississauga.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,328:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/brucemann.ca.conf
2022-09-07 11:04:45,328:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/ipctannerfinancial.ca.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/maaskantfinancial.ca.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/perriwealth.com.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/build-wealth.ca.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/mansfieldprivatecounsel.ca.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/anthonystallone.investmentplanningcounsel.ca.conf
2022-09-07 11:04:45,329:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/liveyourdreamnow.ca.conf
2022-09-07 11:04:45,330:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/personalizedwealth.com.conf
2022-09-07 11:04:45,330:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/visionvest.ca.conf
2022-09-07 11:04:45,331:DEBUG:certbot_nginx._internal.parser:Writing nginx conf tree to /etc/nginx/nginx.conf:
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log alert;
pid /var/run/nginx.pid;
load_module modules/ngx_http_geoip2_module.so;
load_module modules/ngx_stream_geoip2_module.so;
events {
worker_connections 1024;
http {
include /etc/letsencrypt/le_http_01_cert_challenge.conf;
client_header_buffer_size 512k;
large_client_header_buffers 4 512k;
server_names_hash_max_size 2048;
server_names_hash_bucket_size 256;
client_max_body_size 50M;
server_tokens off;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
geoip2 /etc/nginx/geoDB/GeoLite2-Country_20210323/GeoLite2-Country.mmdb {
$geoip2_data_continent_code continent code;
$geoip2_data_country_iso_code country iso_code;
geoip2 /etc/nginx/geoDB/GeoLite2-City_20210323/GeoLite2-City.mmdb {
$geoip2_data_city_name city names en;
$geoip2_data_postal_code postal code;
$geoip2_data_latitude location latitude;
$geoip2_data_longitude location longitude;
$geoip2_data_state_name subdivisions 0 names en;
$geoip2_data_state_code subdivisions 0 iso_code;
map $geoip2_data_country_iso_code $geo_allowed {
default 0;
"" 1;
US 1;
CA 1;
AU 1;
FR 1;
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
gzip on;
gzip_types text/css text/javascript application/x-javascript image/png image/gif image/jpeg;
ssl_protocols TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384 EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH+aRSA+RC4 EECDH EDH+aRSA RC4 !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS !RC4";
sub_filter "http://ipc.digitalagent.ca/" "/";
include /etc/nginx/sites-enabled/*.conf;
2022-09-07 11:04:45,337:DEBUG:certbot_nginx._internal.parser:Writing nginx conf tree to /etc/nginx/sites-enabled/janetpringle.ca.conf:
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
listen 80;
listen [::]:80;
server_name www.janetpringle.ca janetpringle.ca;
# return 301 https://$server_name$request_uri;
location ~ /.well-known/acme-challenge/ {
#allow all;
#root /var/www/html;
root /var/lib/letsencrypt;
location = /.well-known/acme-challenge/iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU{default_type text/plain;return 200 iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU.YLY92kchiIAic-sTm_NC8PejwkvQcMhQKwqu2RV7V00;} # managed by Certbot
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/janetpringle.ca/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/janetpringle.ca/privkey.pem;
proxy_read_timeout 180s;
#Custom Domain Name (Note variable can not be used for server_name directive which is why this is duplicated)
#set $DOMAIN_NAME janetpringle.ca;
set $DOMAIN_NAME ipc.digitalagent.ca;
#Website ID (Needs to match entry in DA_Website table)
#set $WEBSITE_ID 941787;
set $WEBSITE_ID 1234546;
#Liferay website URL
#set $WEBSITE_LR_SITE /web/thepringleteam;
set $WEBSITE_LR_SITE /web/janetpringle-ayw;
# eNewsletter FTP folder for this domain
set $FTP_FOLDER "janetpringle_ca";
include /etc/nginx/conf.d/nginx-custom-https-domain.custom;
#Catch All 404 and redirect to custom 404
proxy_intercept_errors on;
error_page 404 @missing;
# SSL Configuration
location ~ /.well-known {
allow all;
root /var/www/html;
location @missing {
rewrite ^(.*)$ http://$server_name/ break;
2022-09-07 11:05:05,441:DEBUG:acme.client:JWS payload:
b'{}'
2022-09-07 11:05:05,443:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/150716602377/f0dDlA:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDE5MzE3OTEiLCAibm9uY2UiOiAiMDEwMlo2RVRvdzMzY3VaN1g2WmhoNWxLVTBWZmg3OVJCWDlUYkJNWktELWJ0dTAiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLXYzLzE1MDcxNjYwMjM3Ny9mMGREbEEifQ",
"signature": "MBaPq66yQO2BLHFHClsiu0odJZA2fq0YmbqH_BsPaPJ96LqGXkWD9UaRpLjT-3oDQgK6P7lLsL3a3ISe9bwma6UytfhLSLH6BHPQ-jwCorMB2ZAGLbWp7TY6mskJiz417Pkckecn09tI9DlIzQ81xZKB2CQMOocsBhhbveVt7tbu_cTP2ASMovhdEz6PjqB1LEvdN8rpX36sS5EcBRLysnChdvk1ZMh7M5Rx1kiT_1kMgPsBcywlpanGhWrslnjz-kMNkDl7jXUPohvMgPytYpyhJ_MDIk9ms48GBaOwE82yQ6aa3Wsy7nqpo680-ORN5ZUo5YPqUysPY-ovF8camA",
"payload": "e30"
2022-09-07 11:05:05,534:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/150716602377/f0dDlA HTTP/1.1" 200 187
2022-09-07 11:05:05,534:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 07 Sep 2022 11:05:05 GMT
Content-Length: 187
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/150716602377>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/150716602377/f0dDlA
Replay-Nonce: 01010w3buRhKlK7JtS4PU8Fu2FPe6puKxo-EAWKaCd5eJYI
"type": "http-01",
2022-09-07 11:05:05,535:DEBUG:acme.client:Storing nonce: 01010w3buRhKlK7JtS4PU8Fu2FPe6puKxo-EAWKaCd5eJYI
2022-09-07 11:05:05,535:INFO:certbot._internal.auth_handler:Waiting for verification...
2022-09-07 11:05:06,535:DEBUG:acme.client:JWS payload:
b''
2022-09-07 11:05:06,537:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/150716602377:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNDE5MzE3OTEiLCAibm9uY2UiOiAiMDEwMTB3M2J1UmhLbEs3SnRTNFBVOEZ1MkZQZTZwdUt4by1FQVdLYUNkNWVKWUkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzE1MDcxNjYwMjM3NyJ9",
"signature": "LWQ8-RwOnDmnQiUVl5TezV0yKZEBq-KrYWFlh89Ba08swYGwAL_OpMxlgFwUMEYnrMPRx73k3yZoPdEe1BnTom6ZiDjD0Evnb4FGT7mlkr30HNSlyxGhaNtTzfwdauLyKTgyHxfBHllkfdxOUjTiK3Ci4no3kJsMdPhxdRi3x3zRmz2btmg2nbqCmN-8uO_T6fKTSdhCJNc2DrfvVCtI6cUL6LcKq3ihwOlGkrXFHMoP_6VxhUqQmXnY4pZJdU4Z5olVbAObkCJ3LoPpnJjdi384_5onlUajlMQS_E3e7lDprk_QunT3j9Fydd3mJrKlGo86zGmscAcKs6qC-g3Nug",
"payload": ""
2022-09-07 11:05:06,611:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/150716602377 HTTP/1.1" 200 1022
2022-09-07 11:05:06,611:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Wed, 07 Sep 2022 11:05:06 GMT
Content-Length: 1022
Replay-Nonce: 0102Ft9uP44TKwmlgrx0lIE8s6zkmmXNp65V7EdD1gdqsOA
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "3.99.56.255: Invalid response from http://janetpringle.ca/.well-known/acme-challenge/iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU: 404",
"status": 403
"token": "iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU",
"validationRecord": [
"url": "http://janetpringle.ca/.well-known/acme-challenge/iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU",
"hostname": "janetpringle.ca",
"port": "80",
"addressesResolved": [
"3.99.56.255"
"addressUsed": "3.99.56.255"
"validated": "2022-09-07T11:05:05Z"
2022-09-07 11:05:06,611:DEBUG:acme.client:Storing nonce: 0102Ft9uP44TKwmlgrx0lIE8s6zkmmXNp65V7EdD1gdqsOA
2022-09-07 11:05:06,612:INFO:certbot._internal.auth_handler:Challenge failed for domain janetpringle.ca
2022-09-07 11:05:06,612:INFO:certbot._internal.auth_handler:http-01 challenge for janetpringle.ca
2022-09-07 11:05:06,612:DEBUG:certbot._internal.display.obj:Notifying user:
Domain: janetpringle.ca
Detail: 3.99.56.255: Invalid response from http://janetpringle.ca/.well-known/acme-challenge/iRwiSbxWjM5MZW031TJlxnmF2JiB3WPiUueVVG_SbTU: 404
2022-09-07 11:05:06,613:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/auth_handler.py", line 106, in handle_authorizations
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/auth_handler.py", line 206, in _poll_authorizations
2022-09-07 11:05:06,613:DEBUG:certbot._internal.error_handler:Calling registered functions
2022-09-07 11:05:06,613:INFO:certbot._internal.auth_handler:Cleaning up challenges
2022-09-07 11:05:31,606:DEBUG:certbot._internal.log:Exiting abnormally:
File "/snap/certbot/2192/bin/certbot", line 8, in <module>
sys.exit(main())
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/main.py", line 19, in main
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/main.py", line 1744, in main
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/main.py", line 1591, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/main.py", line 141, in _get_and_save_cert
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/client.py", line 530, in obtain_and_enroll_certificate
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/client.py", line 442, in obtain_certificate
File "/var/lib/snapd/snap/certbot/2192/lib/python3.8/site-packages/certbot/_internal/client.py", line 510, in _get_order_and_authorizations
2022-09-07 11:05:31,607:ERROR:certbot._internal.log:Some challenges have failed.
Also I am uploading the complete logfile failure.
janetpringlecertfailure.txt (64.3 KB)
