About 2-3 months ago, following some official instructions, I set up crontab to execute the following command once each day (at a random time):
# *** root crontab ***
# 7:17 am daily
17 7 * * * /mnt/sdb/downloads/certbot-auto renew --quiet --no-self-upgrade
Today I discovered that although crontab is executing the command daily, it didn’t actually renew my certificate. Hence my current certificate expired a couple of days ago and had since been in an expired state.
But when I logged in as root and executed the command as follows (without --quiet), the certificate renewed immediately and my website was now serving the new certificate.
/mnt/sdb/downloads/certbot-auto renew --no-self-upgrade
I saw some others hinting that cron’s environment is different from the one I see when I execute manually. Or that I have to use a wrapper script around the command, or that I have to cd to the directory containing the executable (but I didn’t really need to do that when I executed it manually).
If I add root in front of the command (after * * *) will that fix the problem? If not, how do I fix it so that I don’t have to manually renew the certificate every 3 months?
My server is Ubuntu 14.04.4 LTS (GNU/Linux 3.13.0-88-generic x86_64)
