bitinn
December 14, 2016, 11:43am
1
I can’t believe I still have problems configuring crontab after using VPS for 10+ years, but here is my current problem:
In /var/log/syslog
Dec 14 04:00:01 s2 CRON[25877]: (root) CMD (/home/myuser/cert/certbot-auto renew --post-hook "service nginx reload" > /dev/null)
Dec 14 04:00:03 s2 CRON[25876]: (CRON) info (No MTA installed, discarding output)
And no log for this cron job in /var/log/letsencrypt/ folder.
My certificate isn’t updated automatically. I have to do manual update (does work).
A few troubleshooting:
My cron service is running.
Manually running command works (using my username account with sudo right).
Manual run doesn’t produce error and does log in /var/log/letsencrypt/.
I am using crontab -u root -e to setup my cron jobs.
certbot --version is 0.9.3.
my root account doesn’t have a password, ie. sudo passwd -dl root.
So, should I somehow run cron job using my own account or should I configure root cron job differently to troubleshoot my problem?
Why don’t you try doing it my way.
Create a bash script in /bin called /bin/certbotrenew.sh as follows
#!/bin/bash
cd /opt/certbot
sudo ./certbot-auto renew >> /var/log/certbot-renew.log
sudo service nginx reload
mail -s "CERTBOT Renewals" youremail@wherever.com < /var/log/certbot-renew.log
exit 0
make the script executable
sudo chmod +x /bin/certbotrenew.sh
Then go
sudo crontab -e
and add this line
00 20 * * 1 /bin/certbotrenew.sh
This mails you the log file every Monday when it runs so you can quickly spot any errors in the log file, renewals processed etc.
Works 100% for me never missed a single renewal yet.
Since there is an error of;
There is no Mail Transport Agent installed on the server ( or at least none that the system can find) - hence the bash script with "mail' in it is equally as likely to fail.
You could either install an MTA ( so you get emailed the output) or you can pipe the info into a log ( either on the cron line, or as in the bash that MitchellK suggested).
My guess is that there is a PATH difference between your cron and when running the command on the prompt, hence your cron isn't working correctly.
system
Closed
January 13, 2017, 2:21pm
4
