My operating system is (include version): Ubuntu 14.04.4 LTS
My hosting provider, if applicable, is: AWS
I used webroot method to create a cert and created a cron script for auto renewal. The thing is when I manually run the cron script, it works perfectly. But when running by cron, it always fails.
Here is my cron script:
Note: This is auto-generated file.
@daily root /home/someuser/letsencrypt/letsencrypt-renew.sh domain-name1
The letsencrypt-renew.sh script basically does some checking of the existing cert's expiry date and if less than 30 days, it will start the renewal process. The renewal part looks like this:
log_fn "Certificate expires in ${DAYS_EXP} days."
log_fn "Start renewal process..."
if ! ${CURRDIR}/letsencrypt-auto renew >> ${LOGFILE} 2>&1 ; then
log_fn "Automated renewal process failed. Exiting..."
exit
fi
My log file shows that the cronjob always yields a failure in renewal process:
Wed Sep 28 00:00:01 UTC 2016 Certificate expires in 18 days.
Wed Sep 28 00:00:01 UTC 2016 Start renewal process...
Bootstrapping dependencies for Debian-based OSes...
Ign http:// us-west-2.ec2.archive.ubuntu.com trusty InRelease
Get:1 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates InRelease [65.9 kB]
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty Release.gpg
Get:2 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/main Sources [383 kB]
Get:3 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/universe Sources [165 kB]
Get:4 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/main amd64 Packages [900 kB]
Get:5 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/universe amd64 Packages [375 kB]
Get:6 http:// security.ubuntu.com trusty-security InRelease [65.9 kB]
Get:7 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/main Translation-en [436 kB]
Get:8 http:// us-west-2.ec2.archive.ubuntu.com trusty-updates/universe Translation-en [198 kB]
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/main Sources
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/universe Sources
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/main amd64 Packages
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/universe amd64 Packages
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/main Translation-en
Hit http:// us-west-2.ec2.archive.ubuntu.com trusty/universe Translation-en
Ign http:// us-west-2.ec2.archive.ubuntu.com trusty/main Translation-en_US
Ign http:// us-west-2.ec2.archive.ubuntu.com trusty/universe Translation-en_US
Get:9 http:// security.ubuntu.com trusty-security/main Sources [120 kB]
Get:10 http:// security.ubuntu.com trusty-security/universe Sources [42.5 kB]
Get:11 http:// security.ubuntu.com trusty-security/main amd64 Packages [531 kB]
Get:12 http:// security.ubuntu.com trusty-security/universe amd64 Packages [137 kB]
Get:13 http:// security.ubuntu.com trusty-security/main Translation-en [293 kB]
Get:14 http:// security.ubuntu.com trusty-security/universe Translation-en [82.1 kB]
Fetched 3,794 kB in 6s (582 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
dialog is already the newest version.
gcc is already the newest version.
python is already the newest version.
python-dev is already the newest version.
ca-certificates is already the newest version.
libffi-dev is already the newest version.
python-virtualenv is already the newest version.
The following extra packages will be installed:
libssl1.0.0
Suggested packages:
augeas-doc augeas-tools
Recommended packages:
libssl-doc
The following packages will be upgraded:
augeas-lenses libaugeas0 libssl-dev libssl1.0.0
> debconf: unable to initialize frontend: Dialog
> debconf: (TERM is not set, so the dialog frontend is not usable.)
> debconf: falling back to frontend: Readline
> debconf: unable to initialize frontend: Readline
> debconf: (This frontend requires a controlling tty.)
> debconf: falling back to frontend: Teletype
> dpkg-preconfigure: unable to re-open stdin:
4 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
Need to get 0 B/2,268 kB of archives.
After this operation, 7,168 B of additional disk space will be used.
> dpkg: warning: 'ldconfig' not found in PATH or not executable
> dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
> dpkg: error: 2 expected programs not found in PATH or not executable
> Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
Wed Sep 28 00:00:13 UTC 2016 Automated renewal process failed. Exiting...
But when I manually run the command in /etc/cron
sudo /home/someuser/letsencrypt/letsencrypt-renew.sh domain-name1
The output is successful:
Wed Sep 28 03:20:00 UTC 2016 Certificate expires in 17 days.
Wed Sep 28 03:20:00 UTC 2016 Start renewal process...
Upgrading certbot-auto 0.7.0 to 0.8.1...
Replacing certbot-auto...
Creating virtual environment...
Installing Python packages...
Installation succeeded.
Processing /etc/letsencrypt/renewal/domainname1.conf
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/domainname1/fullchain.pem
/etc/letsencrypt/live/domainname1/fullchain.pem (success)
Wed Sep 28 03:21:30 UTC 2016
