Certbot-auto renew error network is unreacheable
My domain is: vqure
I ran this command: /usr/local/bin/certbot-auto --nginx -d vqure.com -d www.vqure.com certonly
It produced this output: Your system is not supported by certbot-auto anymore.
certbot-auto and its Certbot installation will no longer receive updates.
You will not receive any bug fixes including those fixing server compatibility
or security problems.
Please visit https://certbot.eff.org/ to check for other alternatives.
An unexpected error occurred:
ValueError: Requesting acme-v02.api.letsencrypt.org/directory: Network is unreachable
The operating system my web server runs on is (include version): ami linux 1
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.10.1
Your server needs outbound network access to talk to the Let's Encrypt servers to request a certificate.
thanks for reply peter already we allowed all outbound traffic on server.
Well, that's just what "network is unreachable" is saying. It's not able to reach the network where Let's Encrypt's servers are. You may want to try accessing it through other commands (curl https://acme-v02.api.letsencrypt.org/directory or the like) or seeing what other outbound sites you can access to help narrow down what's going on.
Hi @ajayjha welcome to the LE community forum :slight_smile:
certbot-auto is deprecated and you should remove it and then install a newer version of certbot.
Then show us the new error message from certbot.
OR as @petercooperjr suggested:
if you see for this site it is showing network unreachable.
output of curl command:-
curl https://acme-v02.api.letsencrypt.org/directory -v
  • Trying 172.65.32.248...
  • TCP_NODELAY set
  • Trying 2606:4700:60:0:f53d:5624:85c7:3a2c...
  • TCP_NODELAY set
  • Immediate connect fail for 2606:4700:60:0:f53d:5624:85c7:3a2c: Network is unreachable
  • TCP_NODELAY set
  • TCP_NODELAY set
  • TCP_NODELAY set
  • TCP_NODELAY set
  • TCP_NODELAY set
Try:
curl -Iv4 https://acme-v02.api.letsencrypt.org/directory
curl -Iv4 https://google.com
curl -Iv6 https://google.com
And show the output of:
curl -4 ifconfig.co
curl -6 ifconfig.co
curl -4 ifconfig.io ---> not any response
curl -6 ifconfig.io
output:-
curl -6 ifconfig.co
curl: (7) Couldn't connect to server
And the other commands suggested by Rudy?
In any case I think this is more generic networking issue than something specifically related to Let's Encrypt..
