Auto renewal failing, manual renewal ok
I'm running some servers protected with Letsencrypt and I'm freaking out about how to make auto-renewal work ... if I manually launch the renewal everything works fine.
In the log letsencrypt.log I find this error "Requesting acme-v02.api.letsencrypt.org/directory: Network is unreachable. Skipping."
the server is ubuntu 20 with apache behind a proxy and had set all variables in /etc/environment as well, i also set in /etc/cron.d/certbot export http_proxy = ...... && https_proxy = ...... command, but is the same.
the only different thing from another environment where everything works properly is that the icmp (traceroute) protocol is not open on the firewall.
I honestly don't understand why with the "certbot renew --dry-run" command everything works properly while it doesn't work automatically.
what did i do wrong?
@mbaldazzi85 Welcome!
The best talent on this forum are reluctant to spend valuable time guessing at solutions when they have been provided so little information. Especially since you have indicated a proxy and firewall in your topology... More information would help get you a working solution a lot faster.
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com 1), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My web server is (include version): Apache :roll_eyes:
The operating system my web server runs on is (include version): Ubuntu 20 :roll_eyes:
