https://malcolmmellor.com
I ran this crontab script:
MAILTO=mtwebink@gmail.com
0 */12 * * * /usr/local/bin/certbot-auto renew --quiet --no-self-upgrade
–post-hook “/sbin/service nginx reload”
/bin/sh: 1: /usr/local/bin/certbot-auto: not found
OS:
Ubuntu 14.04
Serverpilot
My web server is:
NGINX (latest version from 2 weeks ago)
I can login to a root shell on my machine:
I’m using a control panel:
putty
How did you install certbot ? The location you are using is incorrect, so basically we just need to find tethe correct location.
if you used the certbot instructions at https://certbot.eff.org/#ubuntutrusty-nginx then the location which be whichever folder you were in when you did the
wget https://dl.eff.org/certbot-auto
command ( rather than /usr/local/bin )
Thank you for your prompt reply.
I think I must have been in the root dir when I installed it. See below is a screen shot
So, would I be correct in saying that I just need to change that path to
/certbot/certbot-auto
Thank you.
Best, Mike
Yes, the path should be
/root/certbot/certbot-auto
if you were logged in as root.
Thank you, that worked, but now it’s not recognising the post hook, I received the following error:
Unable to find post-hook command /sbin/service in the PATH.
(PATH is /usr/bin:/bin)
Shall I submit another ticket for this? Sorry!
Thank you,
Best wishes, Mike
typically the service command is in /usr/sbin so it would be “/usr/sbin/service nginx reload”
if you type “which service” or “whereis service” it should tell you the path
Just to let you know that worked, I couldn’t have done it without you. Thank you!
