I found my certbot version is 0.31.0 but no auto version. I also run sudo find /etc/letsencrypt/live/ -type l* which shows the certificate. But when I run sudo tail -f /var/log/letsencrypt/letsencrypt.log I have an error on line 477.
Any idea ?
niyazi@niyazi-virtual-machine:~$ certbot --version
**certbot 0.31.0**
niyazi@niyazi-virtual-machine:~$ certbot-auto --version
**certbot-auto: command not found**
niyazi@niyazi-virtual-machine:~$ **sudo tail -f /var/log/letsencrypt/letsencrypt.log**
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1272, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 477, in handle_renewal_request
len(renew_failures), len(parse_failures)))
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
niyazi@niyazi-virtual-machine:~$ **sudo find /etc/letsencrypt/live/ -type l**
/etc/letsencrypt/live/cep.niyazibankasi.com/fullchain.pem
/etc/letsencrypt/live/cep.niyazibankasi.com/chain.pem
/etc/letsencrypt/live/cep.niyazibankasi.com/privkey.pem
