Cerbot and certbot-auto show different versions
My domain is: diserva.de
I ran this command: certbot --version || ./certbot-auto --version
It produced this output: certbot 0.10.2
My web server is (include version): Apache/2.4.10 (Debian)
The operating system my web server runs on is (include version): Debian 8.10 (jessie)
This is exactly the question. When running "certbot --version", I get "certbot 0.10.2", when running "./certbot-auto --version", I get "certbot 0.31.0".
The overall question I have is: am I save for discontinuation of ACME TLS-SNI-01?
"certbot renew --dry-run" produces this error when performing the challenges:
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
Attempting to renew cert from /etc/letsencrypt/renewal/www.diserva.de.conf produced an unexpected error: Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.. Skipping.
/etc/letsencrypt/live/www.diserva.de/fullchain.pem (failure)
while "./certbot-auto renew --dry-run" shows no errors.
Hi @fidelio2000
you have installed two different versions. Certbot and Certbot-Auto.
Your certbot-auto is up-to-date, your certbot is expired. So ignore the error of your certbot and use certbot-auto.
PS: Your certificate is ok, has both domain names, both connections are secure.
CN=www.diserva.de
	31.01.2019
	02.05.2019
expires in 66 days	diserva.de, www.diserva.de - 2 entries
So recheck your domain in 40 days if the renew has worked.
Great, thank you for the quick answer. When you say “use certbot-auto”, do I have to actually activate/do/configure anything or am I good to go like that when certbot-auto produces no errors?
I would wait. Your certificate is valide, I don't know, what you have done. Wait 40 days. Your certbot may crash, but that's not relevant.
If your certbot-auto has created the current certificate, it will run again.
If not, start certbot-auto one time manual.
There’s probably a cron job and/or systemd timer that runs “certbot -q renew” using the older Certbot package.
Unless you’ve set something up, the newer certbot-auto installation will probably never automatically renew your certificates, and you’ll have to run “path/to/certbot-auto renew” manually, or else your certificates will expire.
You can probably see how it’s set up with:
cat /etc/cron.d/certbot
systemctl cat certbot.service
systemctl cat certbot.timer
It might be a good idea to simply uninstall the Debian certbot package, and set up a modified cron job or timer that runs certbot-auto -q renew.
