CERT Renewal: Error while running apachectl configtest
Hi there,
I got several messages regarding renewal, and today managed to get around to it. To my surprise after issuing
sudo certbot --apache
I got:
Error while running apachectl configtest.
    AH00526: Syntax error on line 1 of /etc/httpd/conf/le_http_01_challenge_pre.conf:
    Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration
While a file by the name of /etc/httpd/conf/le_http_01_challenge_pre.conf: doesn’t exist on the server in question, running
sudo apachectl configtest
yields
Syntax OK
To make a long story short, the solution was, to uncomment
LoadModule rewrite_module modules/mod_rewrite.so
in file
/etc/httpd/conf/httpd.conf
I think the error message could be more to the point…
Linux gigabyte 5.7.8-arch1-1
apache 2.4.43-1
What version of certbot are you using? Perhaps this issue has been resolved already in the most recent version.
Also, the file le_http_01_challenge_pre.conf is only used and installed for/during the http-01 challenge, so the fact you can’t find it after certbot is done running, is perfectly understandable and normal. However, certbot should enable mod_rewrite when it’s doing the challenge.
community/certbot-apache 1.6.0-1 [installed]
This may be so, but how is a user to know that ? As I said, error messages should aid in devising a remedy, not utter oracle-like gibberish.
That is all fair and improving the error message to guide the user is already on the backlog.
