Usage: ./httpd [-D name] [-d directory] [-f file]
[-C "directive"] [-c "directive"]
[-k start|restart|graceful|graceful-stop|stop]
[-v] [-V] [-h] [-l] [-L] [-t] [-S]
Options:
-D name : define a name for use in directives
-d directory : specify an alternate initial ServerRoot
-f file : specify an alternate ServerConfigFile
-C "directive" : process directive before reading config files
-c "directive" : process directive after reading config files
-e level : show startup errors of level (see LogLevel)
-E file : log startup errors to file
-v : show version number
-V : show compile settings
-h : list available command line options (this page)
-l : list compiled in modules
-L : list available configuration directives
-t -D DUMP_VHOSTS : show parsed settings (currently only vhost settings)
-S : a synonym for -t -D DUMP_VHOSTS
-t -D DUMP_MODULES : show all loaded modules
-M : a synonym for -t -D DUMP_MODULES
-t : run syntax check for config files
Problem was there was something in the OPTIONS env variable that was interfering with your scripts. Perhaps raise a ticket for a warning to the user or filter it out from a front door entry.
“renew” now works.
Thanks
You have a dns entry www.osiris.com.au, but your certificate has only osiris.com.au as domain name. So if someone tries to go to your www version, there is a certificate mismatch.
So create a new certificate with two domain names:
0440 is no good - you need to turn on the “DON’T BLAME SENDMAIL” option for it accept even that!
I do remember getting caught 3 months ago by the same issue… pretty slack for it to be outstanding for 3 years.
