Cert renew trouble Please help!
My domain is:cloud.ferro-estate.ru
I ran this command: sudo nextcloud.enable-https lets-encrypt
The were to many requests of a give type: :Error creating new order: : to many certificates already issued for exact set of domains: cloud.ferro-estate.ru
My web server is (include version): NextCloud 14.1 from snap install
The operating system my web server runs on is (include version): Ubuntu 18.04 LTS
My hosting provider, if applicable, is: no
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot 0.23.0
Hi @iaandr
checking your domain there are a lot of new certificates - https://check-your-website.server-daten.de/?q=cloud.ferro-estate.ru#ct-logs
Let's Encrypt Authority X3 2019-07-28 2019-10-26 cloud.ferro-estate.ru - 1 entries duplicate nr. 5 next Letsencrypt certificate: 2019-07-29 12:08:45
Let's Encrypt Authority X3 2019-07-26 2019-10-24 cloud.ferro-estate.ru - 1 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-07-25 2019-10-23 cloud.ferro-estate.ru - 1 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-07-23 2019-10-21 cloud.ferro-estate.ru - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-07-22 2019-10-20 cloud.ferro-estate.ru - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-07-21 2019-10-19 cloud.ferro-estate.ru - 1 entries
5 in the last 7 days, 24 in the last 28 days.
Why do you create so much certificates? Where are these? You use a self signed nextcloud certificate.
O=Nextcloud
	28.07.2019
	26.10.2019
expires in 90 days
Looks like you have to install the certificate.
Create one certificate, then use it 60 - 85 days, then create the next.
Hi JuergenAuer,
Thanks a lot for your fast support!
The previous admin did not understand why installed a request for a certificate every day and I had to temporarily install a self-signed certificate instead of a public one from LetsEncrypt.
Do I understand correctly that after 2019-07-29 12:08:45 I can request a new certificate from LetsEncrypt for cloud.ferro-estate.ru again to resolve the problem?
You can do that. But more important: Where are the current certificates?
Why don't you use one of these? You don't need to wait if you have one of these certificates and install it.
Hi, JuergenAuer
Unfortunately, I could not find the certificates that the server previously requested (May be is was not saved for use).
Today at 12:32 I tried to get the certificate from LetsEncrypt again, but again I received an error:
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: cloud.ferro-estate.ru
Why is that? Is it possible to reset the counter of the issued certificates once for our domain?
Thanks a lot for your support again!
Maybe a time zone problem, wait some hours.
