I am trying to install security certificates, running home assistant on raspberry pi 3 with python 3.7.3. There is no public IP, using duckDNS. Also created port forward on the router for port 80 and also for port 443. I try to run command as shown below and still get the error. Any pointers will be appreciated, thanks
My domain is: bkraspberry.duckdns.org
I ran this command:./certbot-auto certonly --standalone --preferred-challenges http-01 --email abc@hotmail.com -d bkraspberry.duckdns.org
Requesting to rerun ./certbot-auto with root privileges…
Bootstrapping dependencies for Debian-based OSes… (you can skip this with --no-bootstrap)
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists… Done
Building dependency tree
Reading state information… Done
augeas-lenses is already the newest version (1.11.0-3).
ca-certificates is already the newest version (20190110).
gcc is already the newest version (4:8.3.0-1+rpi2).
libaugeas0 is already the newest version (1.11.0-3).
libffi-dev is already the newest version (3.2.1-9).
libssl-dev is already the newest version (1.1.1d-0+deb10u2).
openssl is already the newest version (1.1.1d-0+deb10u2).
python is already the newest version (2.7.16-1).
python-dev is already the newest version (2.7.16-1).
python-virtualenv is already the newest version (15.1.0+ds-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Creating virtual environment…
Installing Python packages…
Had a problem while installing Python packages.
pip prints the following errors:
Collecting ConfigArgParse==0.14.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 12))
Downloading
https://files.pythonhosted.org/packages/69/cb/f5be453359271714c01b9bd06126eaf2e368f1fddfff30818754b5ac2328/funcsigs-1.0.2-py2.py3-none-any.whl
Collecting future==0.18.2 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 89))
Downloading https://files.pythonhosted.org/packages/63/e3/05b02057b56cd9c59d848b67aff1cc701e1d2237055ebd0d0c1f44331186/zope.deferredimport-4.3.1-py2.py3-none-any.whl
Collecting zope.deprecation==4.4.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 142))
Downloading https://files.pythonhosted.org/packages/c5/96/361edb421a077a4c208b4a5c212737d78ae03ce67fbbcd01621c49f332d1/zope.event-4.4-py2.py3-none-any.whl
Collecting zope.hookable==4.2.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 148))
Downloading https://files.pythonhosted.org/packages/41/b5/378175b959565de41f45c775cdfbf8897aaeaf29a258b94e40bd2661ce46/zope.hookable-4.2.0.tar.gz
Collecting zope.interface==4.6.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 159))
Downloading https://files.pythonhosted.org/packages/4e/d0/c9d16bd5b38de44a20c6dc5d5ed80a49626fafcb3db9f9efdc2a19026db6/zope.interface-4.6.0.tar.gz (150kB)
Collecting zope.proxy==4.3.3 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 189))
Downloading https://files.pythonhosted.org/packages/e2/44/bea546c55488c044351e51ebf23bf440b19876e0069a418cadc1bd5736f7/zope.proxy-4.3.3.tar.gz (44kB)
Collecting letsencrypt==0.7.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 237))
Downloading https://files.pythonhosted.org/packages/fd/21/0c6f33829fadec8aca0c1ebb4d6f8101c05899356a58d1b2e506cb77cf18/letsencrypt-0.7.0-py2-none-any.whl
Collecting certbot==1.0.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 241))
Downloading https://files.pythonhosted.org/packages/b7/1a/121fe6726b36a8517325f8cc66c834de4b4e1bd9dc28e896df8a7ab4f8d1/certbot-1.0.0-py2.py3-none-any.whl (227kB)
Collecting acme==1.0.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 244))
Downloading https://files.pythonhosted.org/packages/67/5f/31ef89f92e610213b4e8e5bf19348f5c20e79f67497709b2d862f18e1274/acme-1.0.0-py2.py3-none-any.whl
Collecting certbot-apache==1.0.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 247))
Downloading https://files.pythonhosted.org/packages/70/cb/cbae8fcccbf613fc65f817fccceefd5370d911e186d604c8657e2bab16df/certbot_apache-1.0.0-py2.py3-none-any.whl (68kB)
Collecting certbot-nginx==1.0.0 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 250))
Downloading https://files.pythonhosted.org/packages/f8/b2/5e79c2b8b4dbaa1dc060388cd47e710013e43578394cce5b727152752f54/certbot_nginx-1.0.0-py2.py3-none-any.whl (45kB)
Requirement already satisfied: setuptools>=1.0 in /opt/eff.org/certbot/venv/lib/python2.7/site-packages (from josepy==1.2.0->-r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 97))
THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
pycparser==2.19 from https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl#sha256=bc15573b7c6edd24407526dbbc7a0bd33d80d8af44231c37f58d73f56ff9cab6 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 115)):
Expected sha256 a988718abfad80b6b157acce7bf130a30876d27603738ac39f140993246b25b3
Got bc15573b7c6edd24407526dbbc7a0bd33d80d8af44231c37f58d73f56ff9cab6
zope.component==4.6 from https://www.piwheels.org/simple/zope-component/zope.component-4.6-py2.py3-none-any.whl#sha256=74f55521dec189c08d98341edce929eba6bb2404662d1878f1b289af46f6f6a5 (from -r /tmp/tmp.q6vEM95TxY/letsencrypt-auto-requirements.txt (line 137)):
Expected sha256 ec2afc5bbe611dcace98bb39822c122d44743d635dafc7315b9aef25097db9e6
Got 74f55521dec189c08d98341edce929eba6bb2404662d1878f1b289af46f6f6a5
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
My hosting provider, if applicable, is: duckdns.org
