Cert failure when running certbot
My domain is: n2ajo.info
I ran this command: certbot --nginx
Domain: n2ajo.info
Detail: 76.223.105.230: Invalid response from https://n2ajo.info/.well-known/acme-challenge/9eKjcjObmM__PEc1czbAOFDqVDWLrNrmvBZdzdM4xQU: 404
My web server is (include version): wordpress 6.7
The operating system my web server runs on is (include version): Operating System: Debian GNU/Linux 12 (bookworm)
Kernel: Linux 6.6.74+rpt-rpi-v8
My hosting provider, if applicable, is: godaddy
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 3.2.0
That's not a web server, but a web application which runs on a web server.
Also, there's no website visible on your hostname. Only some kind of "parking lander" page which doesn't show anything in my webbrowser (visible parts probably blocked by my privacy plugins). And this parking page is actually HTTPS secured by a GoDaddy certificate.
Please make sure you have a working website before attempting to get a certificate.
You must have enabled GoDaddy Domain Forwarding after your first post. Because your DNS records now point to their parking page.
Your DNS A record must be the public IP address for your server. In the first post you show an IP address that belongs to Amazon AWS. How is AWS related to this?
Removing Domain Forwarding is well explained here: I got This error - #6 by Geno11x11
Requests to your domain now show this page:
