http://log.cx-networks.com
sudo certbot --nginx
Requesting a certificate for log.cx-networks.com
Domain: log.cx-networks.com
Detail: Invalid response from http://log.cx-networks.com/.well-known/acme-challenge/nUROT5jdwv881d6ddgE7L99j5HWQewTFExlS46d2IhU [88.198.212.191]: "<!DOCTYPE html>\n<html lang=\"en\">\n <head>\n <meta charset=\"UTF-8\">\n <meta http-equiv=\"X-UA-Compatible\" content=\"I"
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 20.04.3 LTS
Hetzner
no
or certbot-auto --version
if you're using Certbot):
certbot 1.25.0
Hello,
I have seen every now and then in our monitoring tool an error from our server that the service snap.certbot.renew throws an error. The certificate would have expired now, so I took care of it today. In the process, I noticed that the certbot can't renew the cert via an ACME challenge. I have added the error message above. In the log I could see that Certbot writes the necessary location blocks to the configuration.
2022-04-04 13:08:13,598:DEBUG:certbot_nginx._internal.parser:Writing nginx conf tree to /etc/nginx/sites-enabled/log.cx-networks.com:
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
server_name log.cx-networks.com;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Graylog-Server-URL http://$server_name/;
proxy_pass http://192.168.200.5:9000;
location = /.well-known/acme-challenge/qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4{default_type text/plain;return 200 qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4.jFCw7yBESEJIuV5lpW
yih8K5KZ4rvxLk0HRzaLHxLS0;} # managed by Certbot
In the nginx logs I can also see that the request from Let's Encrypt arrives at the server and is returned with a status of 200.
3.67.34.92 - - [04/Apr/2022:13:08:14 +0200] "GET /.well-known/acme-challenge/qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4 HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
Still, unfortunately, a 403 - Forbidden response comes from Let's Encrypt and the certificates cannot be issued.
2022-04-04 13:08:15,943:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Mon, 04 Apr 2022 11:08:15 GMT
Content-Length: 1257
Boulder-Requester: 49544698
Link: <https://acme-staging-v02.api.letsencrypt.org/directory>;rel="index"
Replay-Nonce: 0002hIxYzV4vNH0zjA3D7HfEtMSuDogIiyKpj8BwCXueaaI
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "log.cx-networks.com"
"status": "invalid",
"expires": "2022-04-11T11:08:13Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://log.cx-networks.com/.well-known/acme-challenge/qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4 [88.198.212.191]: \"\u003c!DOCTYPE html\u
003e\\n\u003chtml lang=\\\"en\\\"\u003e\\n \u003chead\u003e\\n \u003cmeta charset=\\\"UTF-8\\\"\u003e\\n \u003cmeta http-equiv=\\\"X-UA-Compatible\\\" content=\\\"
I\"",
"status": 403
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/2089003918/7C-49A",
"token": "qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4",
"validationRecord": [
"url": "http://log.cx-networks.com/.well-known/acme-challenge/qpYLAwnq27nu-bxzmjy4PSicef9nt6R2uHeTMFvoNB4",
"hostname": "log.cx-networks.com",
"port": "80",
"addressesResolved": [
"88.198.212.191"
"addressUsed": "88.198.212.191"
"validated": "2022-04-04T11:08:14Z"
I have tried the following until now:
- complete fresh reinstallation nginx server
- using the default configuration for the nginx server
But still it always comes back an Unauthorized response.
I have already searched many forums, but unfortunately did not find an answer. I would be happy if someone here can help me.
Thanks a lot and greetings,
Leo
