Domain: mydomain.com
Detail: IP: Invalid response from mydomand.com/.well-known/acme-challenge/DzBh8nhlFbwbyetrl2ejI9oFtAB73HwqGE3aBCt9MCo: 404
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Hi @phamduclong22041997,
For future reference example.com is the proper domain name to use if you redacted the actual domain name.
As https://example.com/ shows the intended usages
Example Domain
This domain is for use in illustrative examples in documents. You may use this domain in literature without prior coordination or asking for permission.
Also see:
