My domain is: dhtgurubi.duckdns.org [edited]
I ran this command: from the Nginx Proxy Manager => "Renew Now"
It produced this output: Internal Erroy
As an aside, have a look at Tailscale - it's kind of like a VPN mesh thing that you can install on Home Assistant and on your phone etc, that way you can get remote access to your Home Assistant without a public domain and without making it accessible to anyone else.
With regards to your particular setup, I guess you have a server running nginx proxy manager and that in turn is proxying to your Home Assistant (raspberry pi?), so I'm assuming it's nginx that's terminating TLS and home assistant basically isn't involved.
I'd also assume from the empty responses the server is sending that you are filtering traffic based on IP etc, in which case Let's Encrypts http validation will not be able to access your service in order to complete domain validation.
