Cannot bind to port 80
My domain is: bell-computing.com / gourmetbritain-competition.com
I have two serverpilot apps ie seperate wordpress installs using seperate paths like this
/srv/users/serverpilot/apps/gourmetbritain/public
/srv/users/serverpilot/apps/wordpress/public
I already have a cert for bell-computing and was in the process of creatig a new one for gourmet…
sudo service nginx-sp stop
sudo ./letsencrypt-auto certonly --standalone -d gourmetbritain-competition.com -d www.gourmetbritain-competition.com
sudo service nginx-sp start
then
sudo -H ./letsencrypt-auto renew --dry-run
Attempting to renew cert (gourmetbritain-competition.com) from /etc/letsencrypt/renewal/gourmetbritain-competition.com.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
/etc/letsencrypt/live/bell-computing.com/fullchain.pem (failure)
/etc/letsencrypt/live/gourmetbritain-competition.com/fullchain.pem (failure)
apache/nginx
ubuntu 16.04.4
serverpilot on a digitalocean droplet
no
I would not expect your commands to succeed.
  1. You stop nginx
  2. You ask Certbot to issue certificates via --standalone. So far, so good.
  3. You start nginx.
  4. You ask Certbot to perform renewal.
Step 4 fails because it will use --standalone to perform the renewal (matching the settings you used to issue the certificate initially in Step 2.). However, standalone can’t succeed because nginx is occupying port 80 (due to Step 3).
If you want this to succeed, you need to include the stopping and starting of nginx in the Certbot command you use.
For instance,
./letsencrypt-auto certonly --standalone \
-d example.org -d www.example.org \
--pre-hook "service nginx-sp stop" \
--post-hook "service nginx-sp start"
(or to later update the settings once you already have a certificate):
./letsencrypt-auto renew --dry-run \
Also, something that may help, you can still use Certbot’s nginx plugin (and avoid --standalone), even with the way ServerPilot customizes the installation.
You can achieve this by passing some extra parameters to ./letsencrypt-auto --nginx:
  --nginx-server-root NGINX_SERVER_ROOT
                        Nginx server root directory. (default: /etc/nginx)
  --nginx-ctl NGINX_CTL
                        Path to the 'nginx' binary, used for 'configtest' and
                        retrieving nginx version number. (default: nginx)
My bad. So I issued the command you suggested and it allowed me to find that I had a dns error on one of my records *.domain instead of just domain. Different registras tabulat the records differently. Thanks for your guidance. It works now with an SSL Server labs A rating
