Can not issue SSL certificate for sub domain
manage.medidentkala.com
this is the log of my error:
error1.txt (17.5 KB)
Nginx proxy manager on docker with the Nginx version: openresty/1.19.3.1
ubuntu:21.04 ARM version
Self hosted- Raspberry pi 4
no, I use terminal
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.19.0
Hello.
I had my domains on Namecheap.
Then transferred them to cloudflare. (the transferation is not complete yet).
with Nginx proxy manager I am trying to make have a subdomain, which is manage.medidentkala.com
this works fine with port 80.
When I try to get SSL certificate, I can not and get the errors which you can see in logs.
After some errors also will get banned by "too many request limit",
Also when I had my domains hosted on Namecheap, had the same problem,
Also issued the cloudflare token. but still does not work.
Any help is appreciated.
Respect
Shahin
Welcome to the Let's Encrypt Community, Shahin :slightly_smiling_face:
Detail: DNS problem: NXDOMAIN looking up A for manage-docks.accerun.com - check that a DNS record exists for this domain
That doesn't seem to match:
There is no A or CNAME record for manage-docks.accerun.com:
https://toolbox.googleapps.com/apps/dig/#A/manage-docks.accerun.com
On the other hand, there is an A record for manage.medidentkala.com:
https://toolbox.googleapps.com/apps/dig/#A/manage.medidentkala.com
Hello @griffin .
Thanks for quick reply.
As I said, I had tried multiple times and made multiple domains, and issued certificates for them. Maybe accidentally send wrong log file, because I got a bit tired :slight_smile:
I issued a new certificate now and hereerror.txt (110.5 KB) is the log file of it.
Thanks for helping out
Detail: Fetching http://manage.medidentkala.com/.well-known/acme-challenge/v7lJtnebv7NT1lwBR4_fxQTNJ2_kfWx4UsPotBf8ypw: Timeout during connect (likely firewall problem)
The bold part is probably accurate. Both ports 80 (HTTP) and 443 (HTTPS) appear to be closed for manage.medidentkala.com.
It is probably not the cause.
The website with port 80 is reachable.
Also there is same configuration for both port 80 and 443.
So fire wall may be working properly.
Nope. Both 80 and 443 are closed.
You are right.
How ever Nginx should work properly.
Please let me configure it, and share the results.
cheers.
Hey @griffin , your answer was totally right.
The problem was, I have accidentally white listed my own public IP address.
so I could check the website from home and couldn't understand the problem.
bur after you showing me the ports are closed, then got that there is a problem with network firewalls.
allowed all IP addresses to reach the website, and could easily issue SSL certificate, everything works fine.
Thanks
Glad it worked out smoothly! :partying_face:
