Browsers say certificate is not valid after installation
Hi, I have just installed certificates on my hosting through certbot and it seems to have installed correctly with the ‘success’ message but when i view the domain on any browser now i get the warning of invalid certificate on Chrome, Safari, Firefox etc
My domain is:www.ignitecareers.co.uk
I ran this command:certbot certificates
Found the following certs:
Certificate Name: www.ignitecareers.co.uk
Domains: www.ignitecareers.co.uk
Expiry Date: 2020-02-16 00:06:29+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.ignitecareers.co.uk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.ignitecareers.co.uk/privkey.pem
My web server is (include version):nginx version: nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version):1.10.3 (Ubuntu)
My hosting provider, if applicable, is:rackspace.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.31.0
Hi @ameenaziz,
Your certificate for www.ignitecareers.co.uk is valid—but only for www.ignitecareers.co.uk, not for ignitecareers.co.uk. Your web server sends an HTTP redirect from the former to the latter.
What Certbot command did you use to get this certificate? Could you run Certbot again to add ignitecareers.co.uk as another name on the same certificate? … like -d www.ignitecareers.co.uk -d ignitecareers.co.uk or something.
and after that, have a look at:
https://www.ssllabs.com/ssltest/analyze.html?d=www.ignitecareers.co.uk&hideResults=on
hi schoen,
I ran ‘sudo certbot --nginx’ to attain the cert
can you please let me know what the full command is to add ignitecareers.co.uk without the www
There is a DNS entry for:
Address:  162.13.162.103
But there is no web site there:
curl -Iki http://ignitecareers.co.uk/
HTTP/1.1 404 Not Found        <<<<<<<<<<<<<<<<<<<
Server: nginx/1.10.3 (Ubuntu)
Date: Mon, 18 Nov 2019 01:58:15 GMT
Content-Length: 178
Can you show this message?
Date: Mon, 18 Nov 2019 02:00:53 GMT
Content-Length: 178
I have the same, how can i fix this?
Add an alias in the vhost config file.
[for NGINX it’s as simple as another server_name entry]
server_name www.ignitecareers.co.uk;
server_name ignitecareers.co.uk;
Don’t know how to press words, but there may be a setting in there.
I say that because:
curl -Iki https://www.ignitecareers.co.uk/
Date: Mon, 18 Nov 2019 02:08:12 GMT
X-Redirect-By: WordPress
X-Server: ignite-wp-prod
To recap:
[currently]
http://ignitecareers.co.uk/ [doesn’t exist (yet)]
http://www.ignitecareers.co.uk/ redirects to https://www.ignitecareers.co.uk/
https://www.ignitecareers.co.uk/ redirects to https://ignitecareers.co.uk/
https://ignitecareers.co.uk/ [wrong cert name]
certbot finds only finds www.ignitecareers.co.uk as an option during installation
is there away to install for all variations? https:// www. https://www. etc
any ideas?
I tried changing this in /etc/nginx/sites-available
server_name www.ignitecareers.co.uk; server_name ignitecareers.co.uk;
no luck
Did you restart the web server?
This:
Should look like this:
You should modify enabled files:
/etc/nginx/sites-enabled/<file.name>.conf
How many files are enabled?
ls -l /etc/nginx/sites-enabled/
Here is the output of the default file in /etc/nginx/sites-enabled
after making the change
i did restart nginx sudo systemctl restart nginx
# http://wiki.nginx.org/Pitfalls
# http://wiki.nginx.org/QuickStart
# http://wiki.nginx.org/Configuration
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
    listen 80 default_server;
    # SSL configuration
    root /var/www/html;
            try_files $uri $uri/ =404;
    # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
    #location ~ \.php$ {
    #       include snippets/fastcgi-php.conf;
    #       # With php7.0-cgi alone:
    #       fastcgi_pass 127.0.0.1:9000;
    #       # With php7.0-fpm:
    #       fastcgi_pass unix:/run/php/php7.0-fpm.sock;
    # concurs with nginx's one
    #location ~ /\.ht {
    #       deny all;
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
Here is the output of /etc/nginx/conf.d/ignitecareers.co.uk.conf
  access_log off;
  error_log  /var/log/ignitecareers.co.uk_error_log;
  root /var/www/vhosts/ignitecareers.co.uk/httpdocs;
  listen    443 ssl;
  ssl_certificate /etc/letsencrypt/live/www.ignitecareers.co.uk/fullchain.pem; # managed by Certbot
  ssl_certificate_key /etc/letsencrypt/live/www.ignitecareers.co.uk/privkey.pem; # managed by Certbot
  server_name   www.ignitecareers.co.uk ;
  server_name   ignitecareers.co.uk ;
  location ~* ^/phpmyadmin {
  root /usr/share;
  index index.php;
  location ~ ^/phpmyadmin/(.+\.php)$ {
  try_files $uri =404;
  root /usr/share/;
  #    fastcgi_pass unix:/var/run/php-fpm/ignitecareers.co.uk.sock;
  fastcgi_pass 127.0.0.1:8080;
  fastcgi_index index.php;
  fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
  include /etc/nginx/fastcgi_params;
index  index.php index.html index.htm;
try_files $uri $uri/ /index.php?$args;
location @handler {
rewrite / /index.php;
location ~ .php/ {
 rewrite ^(.*.php)/ $1 last;
location ~ .php$ {
try_files $uri /index.php;
expires off;
fastcgi_buffers 256 4k;
fastcgi_buffer_size 32k;
fastcgi_busy_buffers_size 256k;
fastcgi_read_timeout 3600s;
#      fastcgi_param HTTPS $fastcgi_https;
fastcgi_param MAGE_RUN_CODE default;
fastcgi_param MAGE_RUN_TYPE store;
include fastcgi_params;
# WordPress single site rules.
# Designed to be included in any server {} block.
# This order might seem weird - this is attempted to match last if rules below fail.
# http://wiki.nginx.org/HttpCoreModule
# Add trailing slash to */wp-admin requests.
 rewrite /wp-admin$ $scheme://$host$uri/ permanent;
# Directives to send expires headers and turn off 404 error logging.
location ~* ^.+\. (ogg|ogv|svg|svgz|eot|otf|woff|mp4|ttf|rss|atom|jpg|jpeg|gif|png|ico|zip|tgz|gz|rar|bz2|doc|xls|exe|ppt|tar|mid|midi|wav|bmp|rtf)$ {
access_log off; log_not_found off; expires max;
   # if ($host = www.ignitecareers.co.uk) {
  #    return 301 https://$host$request_uri;
listen    80;
In file: /etc/nginx/conf.d/ignitecareers.co.uk.conf
Update this last section as follows:
listen 80;
And in the first section add the following location:
}#location
I just did some thing similar and was able to redirect requests by adding these in the /etc/nginx/conf.d/ignitecareers.co.uk.conf
if ($host = ignitecareers.co.uk) {
       return 301 https://www.$host$request_uri;
In the file?:
Change these names to anything else:
Like:
server_name localhost;
There is no need to “if host =”, you can redirect ALL to https.
Ok, thank you so much you’ve been very helpful. :smiley:
Feel free to Buy me a :beer: or even better donate that :beer: money to LE
Either way:
-Cheers from Miami :beers:
