Brew Pip Installation Error "Operation not Permitted"
Symaldra.com (Cloudflare-Proxy is active)
brew install python
brew unlink python && brew link python
sudo python3 -m venv /opt/certbot/ (1st Command)
sudo /opt/certbot/bin/pip install --upgrade pip (2nd Command)
sudo /opt/certbot/bin/pip install certbot
sudo ln -s /opt/certbot/bin/certbot /usr/bin/certbot
Following the Discussion here: Certbot doesn't install plugins via brew
and these Instructions:
Mac pip install guide: how to install pip 2 different ways
Certbot Instructions | Certbot
Command 2 and 3 produced:
WARNING: The directory '/Users/username/Library/Caches/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
among other things
and down the line Command 4 produced
ln: /usr/bin/certbot: Operation not permitted
Apache HTTPD 2.4.62 (Unix)
MacOS Sonoma 14.6.1
Not Applicable
I believe so ?
no
zsh: command not found: certbot
Download and install the Python from Python.org
The brew managed stuff is a nightmare and over complicates things.
The Python core team has a nice gui package installer, which is updated as part of their release process, and safely sideloads next to the original system Python.
Will try. Tho brew worked very well for all other things I use (apache, php, mysql, progresql).
i've reseted the server to a Time-Machine Backup from before the previous attempt to ensure that no left-overs from said attempt are on the server and then followed the instruction. However, I am still running into the same issue even without brew.
I realised that I accidentally left out some of the errors. When typing
it says
Requirement already satisfied: pip in /opt/certbot/lib/python3.13/site-packages (24.2)
For anyone having the same issue this is what worked for me:
https://discussions.apple.com/thread/250478382?sortBy=rank
instead of writing
as per instructions step 7
you need to run
sudo ln -s /opt/certbot/bin/certbot /usr/local/bin/certbot
But the first error you've shown was for the commands earlier than that simple ln -s command, so I fail to see the connection.
The error message shown are actually more a pip issue it seems than a Certbot option and the error itself suggests it has something to do with the usage of sudo and the lack of the usage of the -H option, "among others".
Also, Certbot usually needs to run as root anyway, so /usr/bin/certbot should work just fine. I don't see why using /usr/local/bin suddenly makes such a difference.
Frankly: I have no damn clue what I am doing, I am just following Internet tutorials.
When it comes to the lack of the -H option: I followed the Certbot instructions. I don't know what -H is for. And I ... somehow didn't saw it mentioned in the warning message. Whoops.
When it comes to the directories ... it fixed the error of "not-permitted" and According to the linked article, it's because of MacOS and its security features.
And well it works so... why doubt it ?
It's apple rootless guarding that path.
Here's what it restricts, even from root:
You can't modify anything in /System, /bin, /sbin, or /usr (except /usr/local); or any of the built-in apps and utilities. Only Installer and software update can modify these areas, and even they only do it when installing Apple-signed packages.
Ah, Apple. Right.
