I have created an EC2 instance in AWS using "Blackboard Learn for REST and LTI Developers" AMI (3900.0.0).
I am trying to set up an SSL for my instance and mapped the domain name to the instance IP.
I am following this article (Developer AMI) to set up an SSL but it is not working. This part looks ok but its the next step that seems to be the problem.
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/studentdashboard.3utilities.com/fullchain.pem (success)
SSH to your EC2 instance and create a file containing your FQDN from freeddns.no-ip.com and your email address and save to /home/ubuntu/my_ssl_config. The format of this file is important and should follow the example below. The file contains only two lines specifying the key and value pairs used to configure the Let’s Encrypt process, e.g.:
This article doesnt mention any of this.. Developer AMI it just says to go here and add this. but it doesnt say what the file type is etc..
The file name requested is: /home/ubuntu/my_ssl_config
[you may have to build the path if /home/ubuntu doesn't exist]
The file type is... plain text?
The file extension is: none
