Today the script to check certificate status and update ran then caused an error in the bitnami config file.
cron job:
sudo /opt/bitnami/ctlscript.sh stop
sudo lego --email=“rbabb@myemail” --domains=“www.MYDOMAIN.com” --path="/etc/lego" renew
sudo /opt/bitnami/ctlscript.sh start
Error:
AH00526: Syntax error on line 46 of /opt/bitnami/apache2/conf/bitnami/bitnami.conf:
SSLCertificateFile: file ‘/opt/bitnami/apache2/conf/server.crt’ does not exist or is empty
Which would cause to site to stop working for a few seconds and then work again for a little while then error out again.
It was until I did the following lines:
sudo mv /opt/bitnami/apache2/conf/server.crt /opt/bitnami/apache2/conf/server.crt.old
sudo mv /opt/bitnami/apache2/conf/server.key /opt/bitnami/apache2/conf/server.key.old
sudo mv /opt/bitnami/apache2/conf/server.csr /opt/bitnami/apache2/conf/server.csr.old
sudo ln -s /etc/lego/certificates/MYDOMAINNAME.key /opt/bitnami/apache2/conf/server.key
sudo ln -s /etc/lego/certificates/MYDOMAINNAME.crt /opt/bitnami/apache2/conf/server.crt
sudo chown root:root /opt/bitnami/apache2/conf/server*
sudo chmod 600 /opt/bitnami/apache2/conf/server*
That it finally started working correctly again. Do I need to add the move and dynamic links into my crontab to resolve this?
Any help you could provide would be helpful
