When I run AutoSSL from cPanel on my GoDaddy VPS, the Top Level Domain (afaiththatobeys.org) will not pass but all sub-domains under that TLD do pass. Every other domain (15 or so) on the same server have not issues.
I have removed the domain from the server and re-created it. I have removed the Let's Encrypt certificate from the server and received a new one and this does not solve the problem.
My domain is: afaiththatobeys.org
I ran this command: Run AutoSSL from cPanel
It produced this output: Only on TLD...all subdomains are fine:
MASTER DCV: 400 urn:ietf:params:acme:error:dns (There was a problem with a DNS query) (DNS problem: query timed out looking up A for afaiththatobeys.org; DNS problem: query timed out looking up AAAA for afaiththatobeys.org) 400 urn:ietf:params:acme:error:dns (There was a problem with a DNS query) (DNS problem: query timed out looking up TXT for _acme-challenge.afaiththatobeys.org)
My web server is (include version GoDaddy VPS , cPanel 120.0.14
The operating system my web server runs on is (include version): AlmaLinux v9.4.0 STANDARD kvm
My hosting provider, if applicable, is: GoDaddy
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, cPanel 120.0.14
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Not using certbot.
