Auto Renew Issue
I have successfully installed a letsencrypt certificate manually with certbot through the terminal on my imac following the documentation on certbots website and liquidweb.com. The issue that I’m having now is that I need to make sure I can autorenew the certificates. I’m running into trouble with this. Please see the error below that I’m getting. I think the solution may involve hooks but I’m am very new to this so I’m unsure on exactly what to do. I do not have access to my SSH, only FTP. I’m not sure what other options I have to setup automatic renewal.
Specs:
My domain is: ithacalivingsolutions.com
I ran this command: sudo -H certbot certonly --manual --preferred-challenges http -d www.ithacalivingsolutions.com -d ithacalivingsolutions.com
and also
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.ithacalivingsolutions.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’)
Attempting to renew cert (www.ithacalivingsolutions.com) from /etc/letsencrypt/renewal/www.ithacalivingsolutions.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’). Skipping.
/etc/letsencrypt/live/www.ithacalivingsolutions.com/fullchain.pem (failure)
My web server is (include version): Using Liquidweb.com cloudsites
The operating system my web server runs on is (include version): apache
My hosting provider, if applicable, is: Using Liquidweb.com cloudsites
I can login to a root shell on my machine (yes or no, or I don’t know): no
Hi @ststruff,
Normally Certbot and other Let’s Encrypt clients are meant to be run directly on the web server. It sounds like that’s not a possibility in your hosting environment, which makes Let’s Encrypt a more challenging fit for your setup.
Your three main options are
  • change hosting providers
  • persuade your hosting provider to offer a better form of Let’s Encrypt integration
  • write a script to automate this process
The last option would indeed involve hooks, namely the --manual-auth-hook and --deploy-hook options in Certbot, which let you specify scripts that you’ve written that perform the necessary steps.
You might also be interested in the getssl client, which includes a “remote webroot” feature where the webroot location can be on a remote server:
