I am having trouble reissuing certificates for a domain I control: eurekausd.org. I have several subdomains all with lets encryp certificates. The main domain eurekausd.org is currently protected, and I was able to reissue a certificate for it, but all subdomains are unable to get a certificate. They are: cavitt.eurekausd.org, excelsior.eurekausd.org, greenhills.eurekausd.org, maidu.eurekausd.org, oakhills.eurekausd.org, olympus.eurekausd.org, ridgeview.eurekausd.org, staffdirectory.eurekausd.org, and www.urekausd.org. All are giving an authorization error when trying to renew the certificate. All of them have "renewed 10 times" on them, so they have been working for quite a long time. This error has occurred only recently. It is also the only domain that I control that is having this problem, and I have hundereds with lets encrypt certificates.
The hosting environement is Windows Server running IIS (I believe it is IIS 8.x). We use win-acme to issue the lets encrypt certificates. Currently it is versio 2.1.2.641.x64.pluggable.
When I try and issue the renewal the error is " DNS problem: SERVFAIL looking up CAA for cavitt.eurekausd.org - the domain's nameservers may be malfunctioning" (this error occurs for all of them).
The renewal information for cavitt.eurekausd.org specifically is:
Renewal -----------------------------------------------------------------
File: WJLK2oH2zESSh2feFkXeCg.renewal.json
FriendlyName: [IIS] eurekausd.org.cavitt
.pfx password: ********************************************
Renewal due: 7/16/2022 9:26:50 AM
Renewed: 10 times
Target -----------------------------------------------------------------
Plugin: IIS - (IIS)
Sites: 118
Hosts: All
Validation ----------------------------------------------------------------- -
Plugin: SelfHosting - (Serve verification files from memory
(recommended))
CSR ----------------------------------------------------------------- -
Plugin: RSA - (RSA key)
Store ----------------------------------------------------------------- -
Plugin: CertificateStore - (Windows Certificate Store)
Installation ----------------------------------------------------------------- -
Plugin: IIS - (Create or update https bindings in IIS)
History -----------------------------------------------------------------
1: 2/17/2021 5:17:58 PM - Success - Thumbprint 8879FF08969CA3D547CFDB22A1B2F6848B88B20A
2: 4/14/2021 9:02:21 AM - Success - Thumbprint 207A3527D4DDAFD15F5BF7DC3FDF7E1BE8E94E8A
3: 6/9/2021 9:01:36 AM - Success - Thumbprint 8E283A64608F3409562E656B138CF04599AF74A5
4: 8/3/2021 9:04:07 AM - Success - Thumbprint C90FB9CE5D1A06B63DA7D1B44A391C9B20AEE374
5: 9/28/2021 9:03:37 AM - Success - Thumbprint D050DBC234D353AC336FACCE9B116A5609F2CE7E
6: 9/29/2021 10:54:27 PM - Success - Thumbprint EF5CB0693107B3CE752C55310C889009A29B280E
7: 12/2/2021 9:26:53 AM - Success - Thumbprint A9680AF9C82BA13F88C5E6624EA738A9D480089D
8: 1/28/2022 9:27:03 AM - Success - Thumbprint FD5BAF6DE8BF9E7B881A946EC17BBC326DA305DD
9: 3/25/2022 9:25:32 AM - Success - Thumbprint 5B58E733E52EC29D9A11C9B784CB14ABC3EA2528
10: 5/22/2022 9:26:50 AM - Success - Thumbprint 2A2A5809E15929B9BE9ED8BC0A277CCF467056B1
11: 7/19/2022 9:28:53 AM - Error - Authorization failed
12: 8/1/2022 11:08:08 PM - Error - Authorization failed
13: 8/1/2022 11:09:18 PM - Error - Authorization failed
14: 8/4/2022 10:59:25 PM - Error - Authorization failed
When I try and run the renewal the result is:
[INFO] Force renewing certificate for [IIS] eurekausd.org.cavitt
[INFO] Authorize identifier: cavitt.eurekausd.org
[INFO] Authorizing cavitt.eurekausd.org using http-01 validation (SelfHosting)
[EROR] {
"type": "urn:ietf:params:acme:error:dns",
"detail": "DNS problem: SERVFAIL looking up CAA for cavitt.eurekausd.org - the domain's nameservers may be malfunctioning",
"status": 400
[EROR] Authorization result: invalid
[EROR] Renewal for [IIS] eurekausd.org.cavitt failed, will retry on next run
This domain is a client of mine, and it appears that they have Network Solutions as their domain provider. I don't have direct access to the nameserver, but I can get them to make changes if required.
I have a ton of other domains on Network Solutions as well, and I am not having any other problems that I am aware of.
Any help, or anything I can try to get these certificate renewed would be greatly appreciated.
The weird thing is that I was able to "fix" the the root domain "eurekausd.org" by removing the website from IIS, and redoing the process of setting the lets encrypt SSL using IIS and win-acme, and everything went through perfectly. Then, when the old one (the broken one) went through the renewal process, it was renewed and is running perfectly. I tried the same procedure for cavitt.eurekausd.org and it failed with the same error, and I was unable to create a new certificate.
Thanks,
Josh
