Hello,
I am having a problem renewing my certificate for the domain 162skate.org
I tried both DNS and WEB challenges without any success.
command runned:
$ certbot certonly --manual -d 162skate.org --preferred-challenges=dns -v
With the DNS challenge, it asked me to create the acme challenge TXT record, which i did.
but after validating it, i have the following error:
Domain: 162skate.org
Type: dns
Detail: During secondary validation: DNS problem: SERVFAIL looking up CAA for 162skate.org - the domain's nameservers may be malfunctioning
Hint: The Certificate Authority failed to verify the manually created DNS TXT records. Ensure that you created these in the correct location, or try waiting longer for DNS propagation on the next attempt.
I also created the CAA record for 162skate.orgm but it still doesn't work.
Any guess about the error received?
Thank you in advance!
Logs received:
HTTP 200
Server: nginx
Date: Wed, 15 May 2024 08:56:18 GMT
Content-Length: 754
Boulder-Requester: 290956220
Replay-Nonce: 6Jd4kJYiY43cXJAQEIknoCh3srGMO0vWDJ2orXantYr3YaxYnkg
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "162skate.org"
"status": "invalid",
"expires": "2024-05-22T08:55:27Z",
"challenges": [
"type": "dns-01",
"error": {
"type": "urn:ietf:params:acme:error:dns",
"detail": "During secondary validation: DNS problem: SERVFAIL looking up CAA for 162skate.org - the domain's nameservers may be malfunctioning",
"status": 400
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/350996717297/sL-bEg",
"token": "hiqnBgmi4qMlLsEn9I4B9HA5JUiJhz3tEd18WvileV4",
"validationRecord": [
"hostname": "162skate.org"
"validated": "2024-05-15T08:56:13Z"
