We are trying to work on a solution automatically setup SSL for subdomains, but we are hitting the
20 cert per root domain per week limit. Is there a place we can apply for a exception of the rate limit? What is the criteria?
Thanks
Thanks
You can add up to 100 subdomains on each certificate - so that’s 2000 subdomains per week … how many do you need ?
But that would assume we are able to batch request in 100s ,which we can’t , we are issuing cert for each domain as it generates.
Thanks
